longbridgehealey
Somebody tell me if I'm right here. If the oil that comes out of the rear axle shaft is not staying in the end of the axle shaft, in the circular cup where it lubricates the bearings, and is dripping out of the edges of the circular end of the axle shaft, then my problem is the paper gasket, right?
If I'm right, what should I use on the gasket when I put it on? Something like wellseal?
Thanks!
Larry, still learning!!
Thanks!
