TR6 oil for rear shocks
Mickey Richaud
First, welcome to the BCF!
Go to your nearest motorcycle shop and pick up some fork oil. Works great!
:cheers:
Mickey
Mickey Richaud
I'm pretty sure 15-20 weight is very close to original specs. If you want stiffer action, you can go with a higher weight oil. I have Harley fork oil in mine (MGB's), and they feel just right to me. But stand by; I'm sure others will chime in shortly with their thoughts.
TR3driver
Great Pumpkin - R.I.P
Stock was about SAE 10 weight. You can go a little heavier for more damping action, but don't go too heavy. Rumor has it that 30 weight is about the limit without eventually destroying the shock unit.
Even 10 weight fork oil may be hard to find. Look for a shop that specializes in Harley parts.
Or just get shock oil from Moss, 220-304
Geo Hahn
I found this at a local motorcycle shop:
Also on Amazon & ebay I see.
I TR6 What type of oil for TR6 rear shocks? Triumph 2
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
JFS TR6 Rear Oil Seal? Triumph 1
J TR4/4A Oil leak from rear of motor. Triumph 28
warwick-steve Oil for rear axle? Austin Healey 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
J Rear Oil Seal Kit - Spring Austin Healey 9
B How often should you change the rear rear axle oil Austin Healey 9
D Oil Leak at rear of oil pan Spridgets 11
drooartz Rear wheel hub oil seal Spridgets 6
B TR2/3/3A Checking oil in rear axle Triumph 2
AUSMHLY Oil in rear carb Austin Healey 33
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
S Rear crank seal oil leak BN2 Austin Healey 20
R transmission and rear end oil Austin Healey 2
B Rear Wheel Bearing Oil Seal Spridgets 7
CanberraBJ8 Rear axle oil seals - which way is out? Austin Healey 18
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
F More oil leaking...rear seal? Triumph 3
D Oil On Rear wheels MG 6
6 Rear Axle Oil Seals Spridgets 4
M Rear Oil Leak Spridgets 5
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
rjc157 moss rear crank oil seal Austin Healey 4
B TR6 TR6 rear axle oil change Triumph 21
J Rear Axle/Differential Gear Oil Spridgets 13
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
vette Crankshaft Rear Oil Seal Austin Healey 11
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
PAUL161 72 Overdrive rear oil seal question. MG 0
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
longbridgehealey oil from rear axle shaft Spridgets 16
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
ncbugeye Oil from rear hub Spridgets 3
Dudly Rear Diff Oil Triumph 11
C Need info on gearbox and rear end oil for midget Spridgets 5
drooartz Removing the $@#! rear hub oil seals Spridgets 3
R correct rear axle oil Austin Healey 1
