TR6 Rear Oil Seal Housing
Bob Legate
Member
Does anyone know where I can get a new or used rear oil seal housing for a TR6? Moss and Victoria British do not sell them. Thanks, Bob
poolboy
I have one with a new seal.
Send me a PM and I'll see what I can do.
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
JFS TR6 Rear Oil Seal? Triumph 1
J Rear Oil Seal Kit - Spring Austin Healey 9
drooartz Rear wheel hub oil seal Spridgets 6
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 1971 clutch and rear oil seal Triumph 2
S Rear crank seal oil leak BN2 Austin Healey 20
B Rear Wheel Bearing Oil Seal Spridgets 7
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
F More oil leaking...rear seal? Triumph 3
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
rjc157 moss rear crank oil seal Austin Healey 4
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
vette Crankshaft Rear Oil Seal Austin Healey 11
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
PAUL161 72 Overdrive rear oil seal question. MG 0
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
drooartz Rear hub oil seal removal Spridgets 4
J Oil Leak Thru Rear Seal? Spridgets 10
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
2wrench Rear oil seal...silicone or not? Triumph 30
S TR2/3/3A TR3 rear oil seal conversion kit Triumph 3
JPSmit Very Quick Question - rear oil seal Spridgets 2
W T-Series MGTD rear oil seal leak MG 7
tahoe healey rear oil seal vs. gasket Austin Healey 2
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
G TR5/TR250 TR 250/early 6 rear pinion oil seal Triumph 0
Woodie rear oil seal leaking Spridgets 11
cutlass29 Spitfire spitfire mk3 rear engine oil seal Triumph 1
zimmy rear oil seal Spridgets 3
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
A Engine Rear Oil Seal Austin Healey 12
S TR2/3/3A Tr3 rear axel oil seal and shim Triumph 0
S TR2/3/3A Tr3 original rear oil seal Triumph 9
E rear oil seal Spridgets 1
bluemiata90 TR2/3/3A TR3 engine rear oil seal Triumph 23
C rear main oil seal Austin Healey 4
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
J TR4/4A Oil leak from rear of motor. Triumph 28
warwick-steve Oil for rear axle? Austin Healey 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
B How often should you change the rear rear axle oil Austin Healey 9
