Rear oil seal...silicone or not?
2wrench
Pic of my real oil seal. Cleaned the hardware; pressed in
the seal per Bently Manual with grease. Wiping, cleaning;
seal pushes either in or out rather easily.
This leaves me concerned. I do not want any leaks after
installation or I'll have to pull the engine again, probably.
So, I was thinking of putting a little silicone around the
rear oil gasket. Is this all right? It is not in the
text of the Bently Manual to do so. Will this do more
harm than good?
If yes, will this silicone in the picture suffice?
If no to silicone, does heat make this seal expand and
seal?
Thanks
2wrench
2wrench
Took another look at this. Removed excess grease.
Very thin amount of grease left in place. Pressed
in the real oil seal. I like it. Won't go with
silicone on the rubber of the rear oil seal,
as it is not mentioned to do so in Bently Manual.
Excessive grease....not good, in my opinion, (slips around).
Very thin amount works, in my opinion.
Tapped it into place with a 1 X 6 using the flat/wide
face on he rubber.
Platinum
That was the proper way, Den. Ya did good. :wink:
MTribe
Anyone try sealing the rear seal with hylomar? Wondering if that might reduce any leakage?
I'm trying hylomar for the first time on everything. That stuff is sticky!
Brosky
Did everyone remember the copper sealing washer on the top center bolt?
BobbyD
Paul,
Pure dumb luck on my part. I mentioned on the Mail List or in a Forum that I was doing the rear seal and someone reminded me about the copper washer. I grabbed the baggy labeled Rear Seal Parts....and there was a copper washer. I hadn't even noticed it when I removed the bolt.
MTribe
Yup, got the washer, thanks!
I did use hylomar on the oil seal. *Looks* good anyway!
Any torque specs for those seven rear oil seal bolts?
DeltaAir423
N/M
I was running with spit torque specs.
2wrench
2wrench
Bobby: Nice pic and great "arrow" indicator, there.
Mine are a little scruffy.
You're looking good. I'm kinda surprised this
thread was revived.
Brosky
I chimed in on it because I didn't want to see you put it back together without the copper washer sealing that center bolt.
MTribe
Anyone know specifically what the torque specs are for seven bolts securing the rear oil seal housing?
Brosky
The TR6 manual says 22 ft.lbs for the rear engine plate.
2wrench
2wrench
Re: Rear oil Iseal...silicone or not?
Sorry, Paul. I think the rear engine plate is a different part.
He's asking about the rear oil seal housing. Now that's my name
or description; but the Bently might call it something else.
What is the size of those seven bolts?
2wrench
2wrench
z
I'm trying to remember. I think the bolt sizes were dispositive
of what the Bently Manual actually called them. Tell me the bolt
sizes and it might help.
Brosky
2W,
Looks like it could be my big mistake.
According to the TRF Blue Book catalog, those are part #HB810:
HDW BOLT,5/16" UNF X 1-1/4" Bolt
I just found that in the TR6 Manual, the Crankshaft Sealing Plate (which is in the front, "aka the saddle block" and is also aluminum) uses 5/16" UNF bolts and they are at 14 ft.lbs.
22ft.lbs. does seem a bit high for aluminum to steel, because nearly all of the other steel to steel 5/16" are at 22.
2wrench
2wrench
Tribe: This is my (our) dilema. This darned part is
referred to in a couple ways: Crankshaft rear oil seal..
(Crankshaft threw my research off); rear oil seal;
and, in the Bently, I narrowed it down to one of two...
sorry, not what you want to hear.
There it is referred to as either a "Crankshaft cover to
block," or
"Crankshaft sealing block attachment."
I will give the specs for each and tell you what I did.
I remember this dilema.
Crankshaft cover to block: 5/16 inch; 15 to 20 lbs torque
Crankshaft sealing block attachment: 5/16 inch; 10 to 14
lbs torque
I concluded it was one of these two; therefore, I split
the baby, slightly fudged and torqued mine at 15 lbs torque.
The seal looked and felt good; not too much, not too
little....
Brosky, whom I greatly respect, has identified these
little devils as being 5/16, so that part fits.
I'd go with 15 pounds and I'm pretty sure that's exactly
what I did.
Whew......
(Disclaimer: I ain't no authority, I just read like the
dickens. Following my suggestions is done at your own
risk.)
Best to ya,
Brosky
2W,
It do believe that this is NOT the crankshaft sealing block, because that is in the front, also known as the Saddle Block, so I think that you will be safe with the 15, but maybe you might want to move up closer to the 20. JMHO.
2wrench
2wrench
Okay, Paul. I think you're correct that it is not
the crankshaft sealing block nor the saddle block.
This is nagging me cause 20 pounds just sounds too much.
I have to recant in error both on its title and its
pound torque.
I do believe it is referred to as the: rear oil gallery.
The rear oil gallery seal, per the Bently Manual,
is only torqued to 5 to 8 pounds.
Also, as I mentioned previously that size matters....these bolts, per the Bently, are only 1/8 in in their size...not
5/16.
I repeat as before: The size will be dispositive.
If your bolts are 5/16 that hold that rear oil seal
on, then I apologize and I will hush on this issue.
If, however, they are 1/8 inch, then they are the
referred to rear oil gallery bolts and torque to between
5 to 8 pounds.
I will have to take pics of docs to support my opinion.
2wrench
2wrench
This is important to all of us to get the correct
info. Overly torqued or under torqued, either way,
certainly could cause an undesired leak.
Please read:
2wrench
2wrench
The last paragraph in pink on the right-hand column reads:
"The rear oil seal housing has one further important
but oft-omitted detail you will be glad you remembered.
The top bolt only must have a copper washer under its
head to prevent oil leaking from the rear oil gallery."
That is an exact quote. I am sorry if it is difficult
to read.
Therefore, we have reference to this part as both a rear
oil seal and in the next breath it describes the special
bolt which must be paid attention to that has the copper
washer which prevents leaking from the rear oil gallery.
So, rear oil seal and rear oil gallery are used as
synonyms...they mean the same thing.
Now I refer you to the Bently repair manual that
refereces torque settings:
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
JFS TR6 Rear Oil Seal? Triumph 1
J Rear Oil Seal Kit - Spring Austin Healey 9
drooartz Rear wheel hub oil seal Spridgets 6
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
S Rear crank seal oil leak BN2 Austin Healey 20
B Rear Wheel Bearing Oil Seal Spridgets 7
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
F More oil leaking...rear seal? Triumph 3
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
rjc157 moss rear crank oil seal Austin Healey 4
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
vette Crankshaft Rear Oil Seal Austin Healey 11
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
PAUL161 72 Overdrive rear oil seal question. MG 0
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
drooartz Rear hub oil seal removal Spridgets 4
J Oil Leak Thru Rear Seal? Spridgets 10
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
S TR2/3/3A TR3 rear oil seal conversion kit Triumph 3
JPSmit Very Quick Question - rear oil seal Spridgets 2
W T-Series MGTD rear oil seal leak MG 7
tahoe healey rear oil seal vs. gasket Austin Healey 2
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
G TR5/TR250 TR 250/early 6 rear pinion oil seal Triumph 0
Woodie rear oil seal leaking Spridgets 11
cutlass29 Spitfire spitfire mk3 rear engine oil seal Triumph 1
zimmy rear oil seal Spridgets 3
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
A Engine Rear Oil Seal Austin Healey 12
S TR2/3/3A Tr3 rear axel oil seal and shim Triumph 0
S TR2/3/3A Tr3 original rear oil seal Triumph 9
E rear oil seal Spridgets 1
bluemiata90 TR2/3/3A TR3 engine rear oil seal Triumph 23
C rear main oil seal Austin Healey 4
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
J TR4/4A Oil leak from rear of motor. Triumph 28
warwick-steve Oil for rear axle? Austin Healey 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
B How often should you change the rear rear axle oil Austin Healey 9
