Rear axle oil plugs
Wana
Does anyone know where to get a wrench, key, etc. to remove the rear axle oil filler plug and drain plug? Are these two different sizes? Thanks!
GregW
Platinum
Hi Wana,
I could be on crack, but I seem to remember a ½” socket extension fitting in the drain plug. I know I didn’t buy any special tool.
Dave Russell
Yoda - R.I.P
The plugs on mine require a 7/16" square wrench. It is easy to grind the sides of a 1/2" socket extension down to 7/16". I used a 3/8" drive to 1/2" adapter. A short piece of 7/16" key stock from a hardware store could be turned with a wrench. I believe this was original issue in the tool kits.
British Car Specialist sells a short bar that fits exact and you just attach a wrench to it. Cheap, but the shiping will probably kill you. There are some on Ebay with a handle attached.
Keoke
[ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/savewave.gif TH:
I didn't see none on Ebay /ubbthreads/images/graemlins/nonod.gif but i've been doing it for years with a plain ole 3/8" rachet.--Keoke /ubbthreads/images/graemlins/grin.gif
GregW
Platinum
Last week I went to my local hardware store and bought a foot of 7/16” square bar. Cut a 2” piece and fit it in a 7/16” 8 point socket.
Velox
Hi Wana, I had some old pieces from a tap and die kit. One of the larger taps with bad threads had a square end for a wrench attachment that *exactly* fit my drain plugs, I assume it must have been 7/16", you are welcome to borrow it /ubbthreads/images/graemlins/cheers.gif
Don't forget to make sure the axle vent is not plugged /ubbthreads/images/graemlins/yesnod.gif /ubbthreads/images/graemlins/yesnod.gif
Wana
Wana
Thanks for the nice offer, Velox. I'm using a special Iowa 3/8" drive ratchet like Keoke and it works just fine. /ubbthreads/images/graemlins/devilgrin.gif
John Morralee
overdrive
I have a question:what happens to an overdrive when you put the car(mine is a '63BJ7) in reverse with the o/drive engaged? I understand the interlock which protects the o/drive if the driver makes an inadvertent change down but have been told fearful tales of bits dropping off if the o/drive is reversed. I have reversed mine a few times though forgetting it was engaged. No bits fallen so far; am I just lucky? My o/drive does not disengage when the car stops so how is it protected from reversing damage?
Velox
Re: overdrive
John my understanding is the 3-4th gear switch relay only allows the OD energized in those gears,if the gearshift is moved to the 1-2 shift gate (or reverse gate) the switch is OFF and the OD can not engage. The concern is if the switch FAILS in the ON position, then the OD would remain engaged/energized irregardles of gear shift position, and if put in reverse, bits and pieces would fall everywhere, very expensive! That is how it was explained to me, I'm sure others will add in here. One guy was so concerned he kept forgetting to switch off the OD he put a red light on his dash to be lit whenever the OD was on so if he forget and started the car up the light would go on warning him not to use reverse. /ubbthreads/images/graemlins/cheers.gif
Dave Russell
Yoda - R.I.P
Re: overdrive
You are correct. The 3-4 switch is pretty reliable though. You won't hurt anything by putting the car in reverse even if the OD were engaged. It's just when you engage the clutch to back up the car will refuse to move. If you force things, THEN is when the broken parts happen. If the car ever feels like it doesn't want to back up, don't force it.
John Morralee
Re: overdrive
Thank you Velox and Dave my point, which I agree was not made too clearly was : in the reverse gate the o/d does not appear to disengage when you stop because it is engaged when the car is driven off forward in the nomal fashion (or does it dis.and then rengage?).I am glad you found this question bcause I could not find a haome for it!!
Dave Russell
Yoda - R.I.P
Re: overdrive
If the OD relay circuit somehow has the OD engaged all of the time, it should still disengage when the 3-4 switch opens such as in reverse or gears 1 & 2. Then engage again in third or fourth. I repeat, if the car backs up easily, no apparent bind, don't force it, the OD is not engaged in reverse. If it does not back up easily, there is more than one problem. Remove the wire at the OD solenoid & see what happens.
In rare cases, the OD clutch ring inside can mechanically stick. If this happens, tapping on the OD housing can sometimes free it.
If you have the transmission cover off, it should be fairly easy to see what is happening. It's not "that" hard to remove.
A Rear Axle Oil Seal Austin Healey 4
warwick-steve Oil for rear axle? Austin Healey 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR2/3/3A Checking oil in rear axle Triumph 2
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
CanberraBJ8 Rear axle oil seals - which way is out? Austin Healey 18
6 Rear Axle Oil Seals Spridgets 4
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
B TR6 TR6 rear axle oil change Triumph 21
J Rear Axle/Differential Gear Oil Spridgets 13
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
longbridgehealey oil from rear axle shaft Spridgets 16
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
R correct rear axle oil Austin Healey 1
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
Atrus Rear axle - oil type & quantity? Spridgets 3
AUSMHLY Rear Axle oil Austin Healey 1
B Rear Axle oil breather Austin Healey 6
danielnorton Oil leak from rear wheel/axle Spridgets 17
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
