NO FIRE! Misfire
MY66AH
CYl 2 and Cyl 3 have no spark. New plugs, tried different wires and cap. Had timing set but now this. UGH!!!
Jim_Gruber
Rotor. The good ones come from Advanced Distributors.
nomad
Got to be something simple if you have fire on 1 and 4. Got to be the cap or wire's. Are they solid or carbon wires in original cap's?
Kurt.
How do you know they have no spark?
Is this a cap with push on wires or wires fixed by a set screw?
MY66AH
MY66AH
Well with car running I can pull 2 and 3 wires and no change. I'll be bringing my spark tester home tonight.
That doesn't always mean no spark. It could mean sparking at the wrong time, or not enough fuel, or not enough compression, etc.
Did you double check your firing order 1342?
Pythias
solid wires victoria cap. Just ordered lucas cap, rotor and wires.
NO, not Lucas. They"re generally now from India, and use Carbon, of all things, to make them black... get the RED ones from Jeff at Advanced Distributor.
dklawson
Please do not take offense at the following.
As an extension to Trevor's comments, are the spark plug wires going counterclockwise around the cap? If you put the wires on clockwise, then 2 & 3 will fire180 degrees out which would make those cylinders appear "dead".
G
Yeah, they go in the other direction too. :jester:
Can't tell you how many times I've done that. :blush:
Better yet, put the cap back on with no rotor...
dklawson
I have forgotten the rotor more times than I will admit. My worst/dumbest/oh-no mistake was forgetting to turn "off" the kill switch I had installed in one car. I spent half an hour trying to figure out why I had no spark before I remembered the switch.
MY66AH
MY66AH
I think it's the wires. I can pull 2 and 3 off and just barely place the boots on the plug and it starts to even out. put them back on and nada.
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
tr6nitjulius General TR TRF fire Triumph 12
Popeye Elide fire extinguishing balls Restoration & Tools 10
shadowfever Running well, then no fire Spridgets 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
S TR2/3/3A Mis-fire Triumph 6
SD Bugeye Fire extinguisher Spridgets 5
Geo Hahn Off Topic Kidde Fire Extinguisher Recall Triumph 5
Gliderman8 TR6 Fire Extinguisher placement Triumph 6
GTP1960 Spotted this old Chevy fire truck in Porto Portugal Other Cars 3
JFS Wedge Steering shaft / fire wall grommet Triumph 2
PC the fire down below Spotted 7
steveg Best Fire Extinguisher Location Austin Healey 38
J Hunting tach and back fire TVR 8
D Fire wall insulation Austin Healey 36
B battery fire Austin Healey 66
Sopwith_Camel fire! Jaguar 4
DerekJ Engine will not fire! Austin Healey 7
B no fire coming out of coil Sunbeam (Rootes) 4
longbridgehealey Where to mount a fire extinguisher Austin Healey 21
beachbumbarry Engine back fire MG 0
M No fire in the hole!?? Austin Healey 15
A I've got fire Triumph 5
Michael Oritt Fire supression system Racing 12
CZ_Dave FIRE! Under the HOOD! Other Cars 11
tahoe healey fire extinguisher Restoration & Tools 7
T Darn!! Set my car on fire this morning. Triumph 13
Nelson Fire extinguisher mounting Spridgets 3
W Electrical fire Triumph 15
I TR6 TR6 heater fire Triumph 15
S Spitfire For Sale: 1969 Spit Fire MK3 Triumph 1
S "Your car's on fire....." MG 20
steveHealey3000 Fire extinguisher Austin Healey 35
M Leaking oil and fire hazard Triumph 11
DrEntropy frying pan to fire... MG 22
WedgeWorks Spitfire I have the spit who has the fire? Triumph 7
Twosheds How to Fire a Restorer? Triumph 23
JohnnyMead Seam Sealer on the Fire Wall Triumph 4
T Cowl [fire wall] engine bay side holes Spridgets 1
Jer First fire up of the 2009 season... Spridgets 0
JPSmit Last Night's Adventure - Fire Dept. Spridgets 4
scoutll Time for a warm fire and a good book,.... Spridgets 8
martx-5 TR2/3/3A Went To Fire Up the TR3 Today...Got a Problem Triumph 18
healeyboz Fire Extinguisher Spridgets 31
VelodromeRacer Tubing to use to relocate fire ext. system? Racing 3
Jim_Gruber Note To Self - How to start your Spridget on fire. Spridgets 11
LastDeadLast Fire Extinguisher Location Triumph 19
tahoe healey Tahoe Fire Austin Healey 28
rick_ingram Fire Extinguishers and your MG MG 20
roofman TR6 Mounting a fire extinguisher in a TR6 Triumph 10
