Leaking oil and fire hazard
M
Member 10617
As a newcomer to this forum, I have a lot of questions ... many probably dumb questions. But I'll ask nevertheless.
I know TR3s are notorious for leaking oil. Mine leaks, but perhaps not as much as most as I have had some new seals and gaskets installed recently. But leak, it does.
And the oil leaking falls on the headpipe of the exhaust system. Not much, but some. Question is: does this present a fire hazard as the headpipe is one of the hottest pipes in the exhaust system?
Frankly, I don't know how this can be avoided, but I thought I'd ask you veterans.
Deleted member 8987
Generally naught, unless it falls on a hot cat.
Smoke will be your indication.
However, I recall a certain early synthetic oil that A) created fires, especialy on big-block Chryslers with the channel between valve cover and upswinging exhaust manifold and B) threats of lawsuits by the manufacturers of said oil if anyone pointed that out (know a guy in a shop who got a "visit").
Some bigger cars have the header pipe from one side to the other going right under the rear of the oil pan, near the rear main seal, and I have chipped off 1/2" of crystallized burnt oil from main, pan, and leaking valve cover gaskets.
If it was a problem, we'd not have too many LBC's still on the road.
Deleted member 8987
That said, I have no idea what all the synthetics would do.
Regular motor oil, no.
TR3driver
Great Pumpkin - R.I.P
Synthetics are no problem either.
Even gasoline isn't likely to be ignited by a hot exhaust system. Many years ago I was driving a TR3A where the exhaust manifold would glow bright red (due to overly lean mixture), and the carbs would sometimes drip raw fuel right onto the manifold. Gave me quite a scare when I heard the HISS ... HISS ... HISS and saw the red spot that would briefly turn black. But it never burned.
The movies have seriously exaggerated the dangers ... they have to load the cars with dynamite to get them to blow up like that.
gardener
https://sphotos.ak.fbcdn.net/hphotos-ak-s...3_3334027_n.jpg
I think the majority of the time Triumph cars is damaged for the time it's stay in bad storages. When you maintain your car running you have time to check it from time to time and make the upgrades it would need, and in this matter the master is Brosky and his Mimosa beauty TR6. This one go to every island tour. This was taken in a sunset in the beautiful beach of RIncon, PR
M
Member 10617
Many thanks for the reassurance. I never see smoke, but -- as with the case with most of these cars -- I can smell the oil. I think you are right.TOC, if there were a problem there probably wouldn't be many of these cars on the road.
The adventure continues!
M
Member 10617
I wonder if wrapping the header pipe with tape made especially for exhaust systems might cut down on some of the heat so that the oil won't burn or crystallize on the pipe?
poolboy
Where is the oil coming from ? Maybe you're having a problem with crankcase pressure.
M
Member 10617
I don't know about crankcase pressure. The transmission has just been rebuilt and overdrive added. New style seals were added wherever possible. The old transmission leaked; the new one leaks. No change there.
poolboy
Oh. Sorry I misunderstood; so it's oil from the tranny, not the engine.
TR3driver
LexTR3 said:
The transmission has just been rebuilt ... the new one leaks.
I would be having some sharp words with whoever rebuilt it! Believe it or not, they really can be made to not leak.
tdskip
I agree - a newly rebuilt unit should not be leaking.
As the guys said - no fire hazard.
Please don't be shy about asking questions!
E Oil leaking from the Tachometer cable Austin Healey 5
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
Michael Oritt Leaking oil pan Racing 8
F More oil leaking...rear seal? Triumph 3
TRclassic3 TR6 TR6 Leaking oil gallery plug Triumph 5
Coyote1 Carbs leaking oil Triumph 8
N BJ8 steering box leaking oil Austin Healey 11
mountainman TR2/3/3A TR3 Leaking oil pan Triumph 17
Nelson Leaking oil pump?? Spridgets 24
bighealeysource oil leaking from engine side covers Austin Healey 25
Nelson New 5-speed leaking oil Spridgets 10
S TR2/3/3A tr3 Shock oil leaking Triumph 2
T 1500 oil pressure gauge leaking Spridgets 6
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
R oil leaking from new trany with redline syth oil Spridgets 15
bigjones Brake drum leaking differential oil Spridgets 29
T More leaking mineral oil from my 1989 xj6 Jaguar 9
Sopwith_Camel leaking oil in new countrys! Spridgets 6
Got_All_4 ADD ON OIL FILTER LEAKING AGAIN! Triumph 12
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
Woodie rear oil seal leaking Spridgets 11
A Oil leaking from ZS carb Triumph 5
O Leaking Oil around dipstick British Motor Corp 5
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
