TR2/3/3A tr3 Shock oil leaking
sp53
Shock oil leaking. I remember awhile back that somebody commented if a lever action shock worked well mechanically and yet lost fluid the problem might not be too bad. The rational was that the fluid would only leak out to the bottom of the seal at the arm, and not affect the pistons. Does anyone remember that self serving story?
Steve
poolboy
How bad is the leak ?
I cured a mild leak by replacing the oil with Bars Rear Main Seal Repair oil.
PeterK
Mine leaked out over the winter. The cause - no sealing washer on the plug. I added a copper washer and all is well.
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
K TR2/3/3A Testing a TR3 lever shock? Triumph 7
K TR2/3/3A Rebuilding a TR3 Lever Shock DIY? Triumph 8
K TR2/3/3A TR3 lever shock upgrade? Triumph 4
M TR2/3/3A TR3 rear shock link question Triumph 4
JohnnyMead TR2/3/3A Tr3 Rear Shock Link Triumph 4
S TR2/3/3A tr3 lever shock Triumph 0
K TR2/3/3A TR3 Front Shock Install? Triumph 2
mountainman TR2/3/3A TR3 Rear Shock Absorber Fluild Triumph 3
H TR2/3/3A TR3 Rear Shock Removal Triumph 6
txtr3 TR2/3/3A Broken front shock mount on TR3 Triumph 4
jsneddon TR2/3/3A TR3 Tube Shock Conversion??? Triumph 2
B TR2/3/3A 1958 TR3 rear tube shock conversion? Triumph 7
