TR2/3/3A Rebuilding a TR3 Lever Shock DIY?
karls59tr
Bronze
What's involved in rebuilding an Armstrong lever shock? Is it possible to take one apart and replace the valve etc? What is it that wears in these units and can they be brought back to new witthout sending them out to Apple hydraulics or the like?
tdskip
Send them to Peter and crew at NOS Import. You'll get your new ones before you sent you old ones so you won't even miss any driving!
PeterK
I have disassembled the valve part, drained, cleaned, and refilled with new fluid with success. Not the same as rebuilding but sometimes that's all they need.
Platinum
Simple an' easy. The return'd product will last beyond your lifetime. :wink:
Banjo
But... Where's the fun in that?
CJD
I would think the hard part with rebuilding is parts. I haven't seen any internal shock parts available anywhere...
Let us know if you do, though.
John
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
N TR2/3/3A TR3 Gauge Rebuilding Triumph 6
mountainman TR2/3/3A TR3 Carb Rebuilding Service Triumph 2
PeterK TR2/3/3A TR3 seat rebuilding with foam. Triumph 4
RedTR3 TR2/3/3A Rebuilding TR3 Fuel Pump question Triumph 5
S TR2/3/3A Rebuilding a cylinder head Triumph 10
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
