ADD ON OIL FILTER LEAKING AGAIN!
Got_All_4
This is the second time in less then a year that my add on oil filter is leaking at the block. Last fall after it was installed it soon started leaking. 1.5k. After retighten the center bolt and that didn't work (did the same thing today). I replaced the rubber gasket and torque to the factory specks for an original filter. probably 2k this time. Same thing retighten and still leaking. What's going on? Anyone fix a problem like this? Larry
DNK
Check to see there isn't 2 gaskets in the groove. You will need a sharp pick for this.
Another thought,I'm not sure about the 3 ,there was a problem with the ones they sold for the 6's,they leaked and there was a stop production on them. I know TRF (I think it was them) finally had ones that didn't leak.
Got_All_4
Got_All_4
Forgot to mention it's for the 250. It has the oil cooler lines attached too. I quite sure it came from VB. Possibly TRF.
DNK
Well,if it is a couple of years old,check with TRF and see if it is from the bad set.
vettedog72
If it is an O-ring seal, take it to NAPA and find an O-ring the same diameter but slightly fatter. Also, as suggested, inspect to rule out two gaskets.
TR3driver
Great Pumpkin - R.I.P
My suggestion would be to remove the gasket, and check that the flange reaches to the bottom of the groove before something else stops it. Put some machinist's blue (lipstick or magic marker will do in a pinch) all around the edge of the flange, then hold the adapter to the block and rotate it a bit. You should be able to see the signs of contact all around the edge.
Then put the center bolt/adapter in finger-tight, and verify that it clamps the big adapter (still without the gasket) before the threads bottom.
DougF
When installing the o ring, coat it well in grease so that it stays in position. The first time around installing mine, it would not stay in place.
Got_All_4
Got_All_4
Wow! thanks for all the replys. I will remove it some time this week and check the castings and do the blueing test. Excellent ideas. Been thinking about it soom too and woundering if the rubber gasket is shrinking. They are only designed to last x amount of miles between oil changes. That is the one I replaced with is a canister O-ring. I have put thousands of miles on them before they go bad. But should last longer. I'm thinking that the blue test might reviel it's not seating deep enough.
wooolffy
Member
I to just repaired oil leak at block. Pulled out rubber seal and checked location of spin on adapter, it was okay. Put in new seal with loctite gasket eliminator on both sides. Put a light film on adapter rim, installed carefully. So far no leaks. The underside of car is wondering where all the lubrication went.
DNK
Is this the same o ring that will work for the speedo tach o ring against the dash. Everybody says napa ,what do I ask for as I am reinstalling the big gauges in my new dash.
bobh
Is your adapter a one piece casting? If so you may want to scrap it and buy one of the newer adapters. From what I've read and my experience installing the adapters... The center of the adapter comes into contact with the engine block before the outer rim. This prevents the outer rim from compressing the large rubber ring.
I tried a half a dozen of O'rings in various materials and thickness. Nothing sealed the adapter.
The adapters are manufactured by Mocal. At some point they redesigned the adapter as a 2 piece design. The center section is a seperate piece that floats on a spring. This allows for the variations between blocks. The center spring is compresed when you tighten the bolt. Allowing the outer rim to compress the outer seal.
I bought one of the new style adapters from BPNW. It sealed just fine with no extra fiddling around.
The only drawback is the new adapters may not be available with the fittings to run hoses to an oil cooler. BPNW said they had not seen one. This was about a year ago, things may have changed since then.
An alternative if to install a sandwich plate between the filter and the adapter. Mocal makes one that includes an integral thermostat. There are numerous sandwich plates available from several manufacturers. I don't recall the size if the threads or the diameter of the filter. You can check them to find the correct plate.
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
S Add ZDDP to gearbox oil? Austin Healey 29
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
Cutrog1 How do I respond to all responses and add progress report on original article? FORUM Navigation Questions 3
Johnny Can I add to an article that I've completed but not yet published? FORUM Navigation Questions 2
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
T For BJ7/8 Safety: add a quarter light mirror [or two] Austin Healey 6
aero3113 Lighter Add Austin Healey 0
R TR2/3/3A Voltmeter add on reccommendations? Triumph 4
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
Lukens TR2/3/3A Think I'll add a fan on TR3 before I need it. Am I being overly cautious? Triumph 13
dougie Add this to my Bucket List Racing 2
Brosky Easy add on fuse block Triumph 7
S ok, how do I add an image to my posts? MG 5
W how hard is it to add overdrive? Triumph 12
bighealeysource add on electric fan for BN6 Austin Healey 33
1 Electric start as an add on...? British Motorbikes 8
B Anyone used this Limited Slip Add on ??? Racing 15
JPSmit Tonight - ADD car Spridgets 0
T Add some "bling" Spridgets 22
J ADD why do you taunt me? Triumph 10
StagByTriumph VTR 2007 Caravans - add more please Triumph 0
PAUL161 How About This Price For A 71? Then Add Shipping! MG 13
roofman ADD BEER TO YOUR TOOLBOX Triumph 37
S Posting an add question. Spridgets 0
White79MGB TR2/3/3A TR3 Add-On Brake Servo Triumph 7
G Add "Blog Roll Call" to AAW -- U Might Find Y'Self Triumph 11
Guinn add-on heater valve MG 7
78MGB Celeb Car...Add Value To The Car??? MG 14
Bill Redd can you add overdrive? Triumph 6
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
