Anyone used this Limited Slip Add on ???
Deleted member 3577
Worse than terrible...
From all accounts I've heard.
Tran-X is the top rated for the Midget. (clutch type)
Quaife is second. (mechanical)
Both are REALLY expensive.
B
blkcorvair
Exactly why I thought to good to be true. Thanks!
dougie
You usually get what you pay for when dealing with race parts. We only use the Quaife with our Big Healeys. They are race proven and I have never heard of any failures with them.
Dougie
aeronca65t
For what it's worth, I've been running an open diff for years.
The only place it slows me down is at Pocono South and that's a crappy track anyway.
Spridgets are low-powered and pretty well balanced. At the amateur level, I don't think a limited slip is that big a deal in these cars.
I used Quaifes, TranEx and locked rear diff in my racing Spridgets over the years, FWIW, none of the high dollar LSD made me any faster or made the Spridget handle any better, so thses days I just run locked diffs. Hey it was good enough for Mark Donohue :smile:
Hedgehog
I'm with Hap on this. Weld the spider gears and go racing. That's all I've done for more than 15 years and I have had no problems.
Michael Oritt
What is the best way of welding them up? I have a few where there are several separate welds to the spiders and one with massive amounts of metal almost forming a ball around the whole center section.
Deleted member 3577
If yer a demo derby guy...
Ya just throw in a bunch of BB's
I've heard about filling it up with lead.
(These two approaches only work with spider gears enclosed in the housing)
Otherwise you have to be very careful about cleanliness.
Oil impregnation, in the metal, spoils the weld.
Grind off some material.
Preheat the heck out of it with a torch.
And blast it with a spark box.
(Turn her up until it sounds like firing a 50 cal. machine gun)
billspohn
I've run every which way, open diff, locked (welded) diff and Quaiffe.
I disagree with what some people are saying about the locked diff being as good as anything, and also about an open diff being just as good/fast as an LSD.
It all depends on the track. If the track you run at has no tight S curves you can probably get away with running a locker. If you want to run at Portland, with the chicane they use for vintage, you are gong to plow like a bastard and the other cars will drive around you on the inside as you push to the outside of the turns.
If you have no tight turns that unload one wheel when you are coming onto an important straight, you can probably get away without losing much time with an open diff. If you ever ran Westwood BC, where they had a hairpin downhill turn into an uphill drag race, anyone with an open diff would still be sitting there spinning their inside wheel while the guys with an LSD (or locker) accelerated past them.
So while what you guys are saying may hold true on your local tracks, the solution many people want is the best one that works under the widest possible set of circumstances possible.
I think that is the LSD and that's what I wound up with and stuck to after many years of experimentation. Maybe only 2% of your corners would ever cause you to lose any time with a locker, and 20% with an open diff. Each driver has to do his own caclulation of whether the tracks at which he races warrant the significant expense of an LSD.
Monkeywrench
+1
If you weld the rear end your car will be tighten up and will require a different set-up. It really depends on your driving style and the type of car (Mark Donahue was driving high hp, low grip cars, and other drivers complained his cars were too tight for them). It might be worth to drive a someone elses car before going ahead and welding it. Do the same with a Quafe equipped car as well.
Deleted member 3577
It's gonna want to go straight at turn in.
You kinda have to throw it into the corner in order to get it to rotate.
You might have to go with a more aggressive caster angle also.
There is also the issue of your really bad Spridget axles.
(Made from old British coat hangers)
Ask Nial
Monkeywrench
You might have go with a more aggressive caster angle also.
Yup, which might not exactly be the fastest way around the track in a lower horsepower car :yesnod:
Deleted member 3577
I like to call my technique..."Yank & Stomp" :jester:
Not exactly the kind of finesse driving I like to do with the Tran-X (Elva)
dougie
PIR turn #2 chicane, with LSD. Look mom...............no plow!
Dougie
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
steveg Has anyone used a knock sensor? Austin Healey 0
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
MY66AH Has anyone used this paint?? Spridgets 7
K Anyone used Corraseal Rust Converter? Triumph 1
NardisCNC Has anyone used the Oberg Engine Tilt Lift?? Spridgets 15
hilsideser anyone ever used one one these? Restoration & Tools 15
JPSmit anyone used this? Galvanized coating? Restoration & Tools 1
T Anyone used Moss front floor pan replacement panel Spridgets 2
bighealeysource Anyone used a "Car Capsule" Austin Healey 2
gubba Has anyone here used this Rack & Pinion? Triumph 8
vping Anyone have Used seat covers or interior bits.? MG 4
B anyone used a Gearflix shift knob? Triumph 7
B Anyone used Ratco shock in spring set up? Triumph 0
D Anyone used a CoolCat fan? Jaguar 7
J has anyone used pacesetter headers and monza exhau Triumph 2
Mark Jones Hughes' Carburettors - Anyone used them? Triumph 0
J Wedge does anyone have a good used head for tr7 Triumph 0
Moose33 Gunson's Colortune - Anyone used 'em? MG 4
A Anyone used Car On Line Inspection Service? Restoration & Tools 4
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
