Seam Sealer on the Fire Wall
JohnnyMead
I'm cleaning up the body panels under the hood, getting ready to paint. I've knocked off some pitch-like material that looks like it was sealing metal seams in the fire wall. Was that original stuff?
John
TR3A 75605L
Moseso
Yes.
I knocked a bunch of that stuff out of mine during the repaint -- and then replaced it with a (hopefully) non-hardening compound on reassembly. Unlike the factory, I didn't want to paint over it.
TDHoward
NOt to hikack the thread, but...
The body I used as a replacement on my Spitfire was a late body from an 1980 model. Rather than normal "dummy" type seam sealer, it has what looks like an expanding foam type over the metal to metal seams.
It was painted over with the original color. This is a first for me, but I believe it to be from the factory.
In the late cars did BL use this dense yellow foam sealer? or was this added later? It seems to have held up very well.
Any ideas, input?
tr8todd
That is the stuff they used on the TR7 and 8s. It comes off nicely with a drill mounted wire brush. It also burns so if you are welding onto a panel, you have to make sure there isn't any of that stuff on the back side of the panel. Makes welding in roll bars an adventure.
B TR2/3/3A seam sealer front fender and cage muts, undercoat Triumph 7
drooartz Seam sealer for fender beading? Spridgets 9
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
P What's the best seam sealer to use for panels on bare shell? Restoration & Tools 7
PatGalvin Seam Sealer for Engine Compartment Triumph 21
J Seam Sealer, do I need it? Spridgets 1
R TR6 TR6 Interior Seam Sealer Issue, Restorers! Step In Triumph 4
1 Removing seam sealer? Austin Healey 6
C Seam sealer in the Engine compartment? Triumph 1
C Best way to remove seam sealer? Triumph 5
fabmandan Seam sealer question Spridgets 8
C Under body seam sealer? Triumph 2
Lin Seam sealer - original application Austin Healey 2
fmichaels seam sealer Spridgets 9
71tr body panel seam sealer Triumph 1
Boink Fender seam annoyance... Spridgets 4
Rob Glasgow Seam Caulking Austin Healey 4
R removing black seam sealing Austin Healey 3
M_Pied_Lourd Body Seam Triumph 8
M Seam seal or not??? Triumph 7
T TR2/3/3A TR3A rear valance lower seam Triumph 2
M TR2/3/3A TR3 body question seam or no seam Triumph 7
T Question on seam welding - why not do it? Triumph 18
jjbunn Chrome seam covers Triumph 3
6 Seam Sealant: Remove, Replace, Leave Intact? Spridgets 1
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
S TR2/3/3A temp gauge sealer Triumph 7
D TR2/3/3A Sealer plate Triumph 4
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
S TR2/3/3A steering box sealer Triumph 9
T TR4/4A Head gasket sealer question Triumph 7
KVH General Tech Gasket Sealer and Sealants Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
S TR2/3/3A gasket sealer for the bear plate Triumph 7
Patrick67BJ8 Sealer between fenders and shrouds Austin Healey 12
PatGalvin Front Wing Sealer Plates Triumph 5
M Tank Sealer in Alu. Fuel Tanks Austin Healey 4
KVH Fuel Tank Sealer Triumph 3
DNK Fittings Sealer Triumph 6
B Gas tank sealer...whats your opinion? Triumph 29
TulsaFred Fender beads look kinda lousy, sealer? Spridgets 9
M Water Pump Gasket & Sealer Spridgets 10
Superwrench Rear shroud sealer Austin Healey 3
sail Gearbox Sealer Triumph 2
CinneaghTR Oil Pan Gasket Sealer? Triumph 14
V Valve cover gasket & sealer??? Spridgets 11
Tabcon Thread Sealer on Wet Liners? Triumph 5
