TR2/3/3A temp gauge sealer
sp53
I am back on the tr3 after our road trip to the Mexican Border. We drove that way to see the sun because a while back we have had largest recorded snow fall for a day in Washington. Anyways I posted some temp gauge pictures I took after trying to install the temp gauge along with what is published as to how the gauge routes. This is the best I could do-- those guys must have been 16 years old to get up and under the dash, I am working with a stock gauge and very fearful of breaking it. I was able to get that small loop to get the tube going back and around the heater and one loop by the coil. The picture of the loop under the dash is difficult to see if you do not know what you’re looking for plus I would add the factory picture is an artist drawing. Anyways, I was going to hook up one of the last ties and could not remember if there is an O ring on the sender bulb or not, or anything else to help seal.
steve
TR3driver
Great Pumpkin - R.I.P
Nope, it's just metal-on-metal.
I like to smear some teflon pipe dope on the seating part of the bulb, and on the threads of the nut, just to make it easier to get out next time. But it's certainly not needed to make it seal.
DavidApp
Very neat installation.
I got one of the modern look alight gauges which came with a green "O" ring on the nut that threads into the thermostat housing. Was not sure if the "O" ring was needed or not so I left it on. So far no leaks.
David
S
sp53
Thanks David inwardly that is what I was looking for the validation of neat and tidy without proceeding the fall with pride. For me restoration is also artistic expression were I do not have to be super creative but be able to replicate. Again, it makes it easier for me to follow a blue print than create one to be artistic.
CJD
I hear ya! We spent a month in Colorado...most snow they have had since the 1970's...at least. Next move was to Vegas, but we kept heading west, get caught by closed roads due to snow...drop a hundred miles south and try new roads west...until we wound up stuck on a corner in Winslow Arizona. Literally. The road to Phoenix (to continue south) was closed with snow, the road to Vegas was closed for the first time in it's history, and I40 was closed both directions. We finally dug out the RV...again, literally...and made Vegas 4 days late. In between all this we spent one night in 5 degree temps with no propane, drove through Flagstaff while 2 feet of snow came down in 3 hours...and have decided that wintering in an RV is doable, but NOT by us!! The 8th straight day of standing on the slick roof shoveling snow off the slides reminded me that I am almost 60. Continuing this lifestyle will not end well.
Soooo...in San Francisco this month, but we are heading back to Texas with our tails between our legs next month. No more winter RV trips above 30 degrees latitude! The open topped Triumph calls us home
S
sp53
Wow John we were going to go over Phoenix to see my wife’s sister and were considering going up through Salt Lake, then Boise and back, but she was not home. We were checking weather on her phone, and they made it sound doable. I already felt I was in a combination of the move Titanic and Gilligan’s Island, so we would have sunk for sure. When we came through Oregon and after cutting over to coast to miss the mountain passes, went to Eureka Cal. From there, we took 299 through Weaverville to get back to I-5 at Redding. The Phone said no snow, not true, Snowing at Weaverville plus 299 is a crazy wild road. When we got closer to Redding, we saw all the damage from the big fire. I remember this big old white house sitting out all alone is this burned landscape with snow. Anyways, if I would have gone the Phoenix route we would have stared in the same move. The moral to the story is do not trust the Phone.
CJD
How funny...we are passing within 100 miles of each other! We’ll be heading back down and through Phoenix in about 2 weeks. So I assume we’ll pass again at some point. I need to ditch the RV and get back to road trips in the Triumph!
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Editor_Reid Water Temp Gauge Austin Healey 5
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A removing the temp gauge needle Triumph 5
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
R Capillary tube temp gauge Austin Healey 7
R TR2/3/3A TR3A tired temp gauge Triumph 5
RickPA Water temp gauge reads low Austin Healey 6
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
Gundy Temp gauge on Mk3 Midget Spridgets 4
M water temp gauge Spridgets 7
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
T TR4/4A How hot at radiator neck when temp gauge is reading innthe middle Triumph 6
B Temp gauge capillary tube Austin Healey 3
J Picture of temp gauge , Austin Mini British Motor Corp 2
Mink TR4/4A Temp gauge/sender question Triumph 15
N Temp Gauge No-Go Spridgets 5
A TR6 Temp gauge Triumph 11
J TR4/4A Fuel and Temp Gauge NightMare! Help! Triumph 24
G TR2/3/3A TR3 Temp gauge Triumph 2
60TR3A TR2/3/3A TR3A Temp Gauge Not Working. Help! Triumph 9
NutmegCT temp gauge substitute? Restoration & Tools 4
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T TR2/3/3A TR3b temp gauge and heater hoses Triumph 10
S Temp gauge capillary tube Austin Healey 8
H Temp gauge stopped working....any common cause? Austin Healey 9
C TR2/3/3A Removing Temp gauge Middle panel TR3A Triumph 3
Kleykamp Temp gauge rebuilder?? Triumph 6
6 TR2/3/3A electric coolant temp gauge in TR3... Triumph 6
W EType Temp Gauge Jaguar 6
tinman58 TR2/3/3A TR3 temp gauge Triumph 13
BOBBYR Water Temp Gauge Austin Healey 5
P Fluctuating temp gauge British Motor Corp 3
T TR2/3/3A TR3/4 elec. temp gauge Triumph 6
DNK Temp Gauge Triumph 16
Gordon_Dedrick TR2/3/3A TR3A temp Gauge Triumph 2
Andrew Mace Post-War Other My [Herald] temp. gauge doubles as an ammeter!? Triumph 8
Bruce Bowker temp gauge Austin Healey 2
Scott_Hower Fuel and temp gauge not working MG 5
Tinkerman TR2/3/3A TR3A Temp Gauge Sensor Tube Routing Triumph 2
K TR2/3/3A TR3 Temp Gauge Upgrade? Triumph 5
K TR2/3/3A Reliability of TR3 Temp Gauge? Triumph 16
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
