Alex Grant
Member
I have a 66 tr4a posi ground.Temp gauge doesn't register. I pulled the gauge out and made sure it worked by connecting straight to 12 volts and grounded out .The needle responded by moving all the way over, so that's telling me the gauge works. I have a new electronic pos. ground vol. stab, installed in the car and checking this out with a digital meter the stab. Is putting out 10 volts. I ran a wire from the instrument side of the stab. to one side of the gauge and ran another wire from the other side of the gauge to ground to see if gauge will still move. With the ignition on , the gauge needle will only move a hair. I feel the gauge being grounded out should move all the way over but at a slightly lower rate than being hooked up to 12volts. Can't figure this out.
