TR2/3/3A TR3A tired temp gauge
RonR
Folks,
What is the likely causes for a capillary tube temperature gauge to stop working, and is it repairable?
The is a1.5-inch long section where the outer "coil" is missing, but it use to work even with that is.
Thanks.
Ron
Geo Hahn
I think that coil is just there to help prevent kinking as the line is bent.
The usual failure mode is a leak - the ether inside the tube escapes.
Can be fixed, even possible as a DIY project though I have yet to attempt it. Certainly rebuildable by any of the usual gauge shops.
dklawson
If any of the solder joints fail or the capillary tube fatigues and develops a crack the ether trapped in the expansion bulb and tube will leak out and the gauge stops working.
They are repairable either professionally or as a DIY project. The only caveat against a DIY repair that I will make is as follows. IF the gauge dies where the needle is not resting on the lower stop peg, then more is required than basic repair. Such gauges should be left to the pros.
If on the other hand the needle is resting on the lower stop peg and the gauge just stops working... use the DIY repair method discussed in the link below. HOWEVER, I suggest you use dry ice for the repair instead of the salt/ice cold bath. Dry ice cooling is much colder, cleaner, and does not result in any possible corrosion of the capillary tube's protective spring.
DIY Gauge Repair Link
TR4nut
If you need it rebuilt, I recommend Moma in Albuquerque. I visited there a couple of years ago and got to watch various repairs, including a rebuild of a capillary temp gauge. They have the expertise to do a really nice job.
Crankshaft
I used the instructions that Doug's link refers to with great success, even with my trembling hands.
I really believe, if I can do it, anyone can.
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Hamish Racing TR2/3/3A TR3a video Triumph 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
angelfj1 TR2/3/3A TR3A Stone Guards Triumph 3
Hamish Racing TR2/3/3A 1959 TR3a used in anger Triumph 5
