Engine will not fire!
DerekJ
Here is another mystery to solve
Yesterday I took the car out for a final test prior to my first event this year. With a new Odyssey Racing battery it fired up first time after three prods of the Webers. Great 45 minute test, car ran perfectly with some high speed work. Parked it on the driveway and had some lunch. Went out an hour or so later to move it to the garage and it wouldn't start! Turned over perfectly but not a splutter, nothing. I assumed no spark.
Last year I fitted a Powerspark ignition system, same as the Pertronix. I assumed that may be the problem. I removed a plug and earthed it to the block but couldn't see a spark. As you can't test a Powerspark I re-installed the points. I got a yellowish spark but still nothing. No spluttering or attempt to fire up.
Powerspark told me the system is more sensitive to a poor coil than points are so I installed a new Lucas Sports coil and obtained what I thought is a pretty good bluish spark, but still not firing when I try to start it. I removed the fuel supply to the last Weber and fuel pumped through perfectly. I also added a gallon to the tank and cleaned up the plugs, still nothing.
In addition I replaced the carbon post in the dizzy cap and also tried a couple of other rotors. Still wont fire even though I get a spark when earthing to the block. That's it for today, time for a drink!
The timing of the distributor was altered quite a bit when I switched from points to electronic so it may be out for the re-installed points however I still think it should at least fire up and cough and splutter. However, tomorrow I will re-install the electronic ignition to see if it will start, which would mean it probably was a coil problem. I could replace the dizzy cap but I don't think that is the problem as Im getting a spark.
Any other ideas? Ive got a spark, I believe Ive got fuel and Ive got compression, its supposed to start!
Its a mystery why it wouldn't re-start on the driveway after running perfectly. What happened during that time?
BTW. The new Lucas Sport coil is 2/3 the size of the old one. Is that increased efficiency or just cost cutting?
Keoke
Cutting Cost-----:angel2:
AH100M
Many years ago, during the fuel crisis, my Alfa had the same problem. Ran great, went to the gas station fill the tank. Wouldn't re-start. Had spark, compression, fuel. Checked spark timing, can timing, everything. Drove me nuts for a weekend. Well... I had fuel but it was BAD fuel. Try running it out of a can of known-good fuel. (I think on the Webbers you can remove the lid of the float bowl and replace the fuel, right?). Worth a try.
RAC68
Derek,
I thing Bill may have something. I have been caught in a similar situation and ran into an issue after doing something as simple as replacing the spark plugs. I took the car to fill up on high test and I just about made it back home when is completely stopped and wouldn't restart. After checking everything I could think of and then some, a friend convinced me to block the fuel from the tank and use fuel from another source. Once flushed from the carbs, the engine started and has been running ever since.
It turned out that the station I purchased the gas from had just previously received a new supply that turned out to be contaminated (I have no idea with what water, fuel oil, ???). Every high performance modern car that had purchased this Premium fuel suffered substantial damage and my Healey suffered the least (cleaned the new plugs and flushed and cleaned the carb, fuel lines and pump).
Good luck,
Ray (64BJ8P1)
blueskies
You mentioned that you have compression, so I assume that you checked to make sure that the valves are moving up and down, and that it's not a timing chain problem. This reminds me of that Lucas poem that someone posted the other day . . .
DerekJ
DerekJ
Success!
The replacement Powerspark arrived today and I decided to fit it hoping that there was not some electrical problem with my car that would blow this one as well. After installation the car fired up first time. I have no idea why the unit failed when the car was switched off and stationery or why the car would not start when I re-fitted points even though their was a spark. I suppose it can only be because the timing set up is different but Im still surprised I didn't even get a cough or splutter. Its worth bearing in mind if you are only carrying points as a replacement. The Powerspark module is very reasonably priced so I have just ordered another one to carry as a spare. I now also have a perfectly good spare Lucas Sport coil!
If you are going to break down there is no better place than your own driveway!
blueskies
That sounds like good news! Let's see, don't forget the extra ignition parts, the spare fuel pump, the special jack, the hammer for the knock offs, an assortment of tools . . . what am I forgetting?
The part about breaking down in the driveway sounds familiar. On the old Sunbeam, the front left suspension collapsed and the wheel folded flat under the car, just after a long drive at highway speeds, a few feet from the driveway.
Success!
Patrick67BJ8
Success!
I've had simiar problems over years of owning my Healey and i think you still have an intermittent problem. White/black wire in the trunk attached to the cut-off switch?
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
beachbumbarry Engine back fire MG 0
T Cowl [fire wall] engine bay side holes Spridgets 1
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
