no fire coming out of coil
bbonner48
have fire going into coil but not out of coil. Car won't start. When turn the key on it sparks and after turning the engine over and it doesn't start it sparks after trying to start. Some said maybe a short in ignition switch. This is Flame thrower electronic ignition. Husband thinks it is the ignitor in the distributor? Any suggestions.
Deleted member 8987
Power on and off spark usually means ignition switch okay.
Probably an igniter. I think there is an on-line troubleshooting process. I'll see if I can find it again.
B
bbonner48
Hopefully you are right. We ordered one and it is on its way. Had to order from out west so takes a few days. Should be here today or tomorrow. Thank you so far you seem to be on the same wave length as my husband after trying several other things. Thank you for your help.
LarryK
Did the fire come out of new coil?
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
tr6nitjulius General TR TRF fire Triumph 12
Popeye Elide fire extinguishing balls Restoration & Tools 10
shadowfever Running well, then no fire Spridgets 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
S TR2/3/3A Mis-fire Triumph 6
SD Bugeye Fire extinguisher Spridgets 5
Geo Hahn Off Topic Kidde Fire Extinguisher Recall Triumph 5
Gliderman8 TR6 Fire Extinguisher placement Triumph 6
GTP1960 Spotted this old Chevy fire truck in Porto Portugal Other Cars 3
JFS Wedge Steering shaft / fire wall grommet Triumph 2
PC the fire down below Spotted 7
steveg Best Fire Extinguisher Location Austin Healey 38
J Hunting tach and back fire TVR 8
D Fire wall insulation Austin Healey 36
B battery fire Austin Healey 66
Sopwith_Camel fire! Jaguar 4
DerekJ Engine will not fire! Austin Healey 7
longbridgehealey Where to mount a fire extinguisher Austin Healey 21
MY66AH NO FIRE! Misfire Spridgets 12
beachbumbarry Engine back fire MG 0
M No fire in the hole!?? Austin Healey 15
A I've got fire Triumph 5
Michael Oritt Fire supression system Racing 12
CZ_Dave FIRE! Under the HOOD! Other Cars 11
tahoe healey fire extinguisher Restoration & Tools 7
T Darn!! Set my car on fire this morning. Triumph 13
Nelson Fire extinguisher mounting Spridgets 3
W Electrical fire Triumph 15
I TR6 TR6 heater fire Triumph 15
S Spitfire For Sale: 1969 Spit Fire MK3 Triumph 1
S "Your car's on fire....." MG 20
steveHealey3000 Fire extinguisher Austin Healey 35
M Leaking oil and fire hazard Triumph 11
DrEntropy frying pan to fire... MG 22
WedgeWorks Spitfire I have the spit who has the fire? Triumph 7
Twosheds How to Fire a Restorer? Triumph 23
JohnnyMead Seam Sealer on the Fire Wall Triumph 4
T Cowl [fire wall] engine bay side holes Spridgets 1
Jer First fire up of the 2009 season... Spridgets 0
JPSmit Last Night's Adventure - Fire Dept. Spridgets 4
scoutll Time for a warm fire and a good book,.... Spridgets 8
martx-5 TR2/3/3A Went To Fire Up the TR3 Today...Got a Problem Triumph 18
healeyboz Fire Extinguisher Spridgets 31
VelodromeRacer Tubing to use to relocate fire ext. system? Racing 3
Jim_Gruber Note To Self - How to start your Spridget on fire. Spridgets 11
LastDeadLast Fire Extinguisher Location Triumph 19
tahoe healey Tahoe Fire Austin Healey 28
rick_ingram Fire Extinguishers and your MG MG 20
roofman TR6 Mounting a fire extinguisher in a TR6 Triumph 10
