TR2/3/3A Is there a timing cover seal that will last more than a couple of year?
TR4nut
i think some of the different thoughts here are because the tensioner is located on the front engine plate on a TR3, but on the timing cover itself on a Spitfire/TR6.
T
TuffTR250
If you haven't in the past, the next time follow the sequence in Bentley for your 250 whereby the cover is installed before installing the oil seal sleeve. That will tilt the lips of the oil seal inward, toward the engine rather than outward, toward the damper as they would if installed before installing the cover.
Poolboy, good point! Might also be good idea to leave the bolts loose on the timing cover and quickly install the oil sleeve before the sealant on the cover goes hard, then tighten the cover bolts. That might help center the seal on the shaft.
Bob
CJD
Until I watched this thread continue to grow, I had no idea the front seal was even an issue. I've always installed it with the engine on a stand and not had any problems. I have to assume most of these issues are when installing it while leaning deep over a wing into the engine bay??
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
JFS General MG Timing Cover Oil Seal MG 7
KVH General Tech Timing Cover Seal Triumph 3
vette Timing Cover crankshaft pulley seal Austin Healey 6
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
L BN1 front timing cover seal Austin Healey 2
R Timing cover oil seal MG 3
PatGalvin Timing Cover Seal Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
PeterK TR timing cover seal Triumph 3
KVH Timing Cover Seal Triumph 6
E TR6 TR6 Timing Cover Seal Triumph 7
Tinkerman Success w/ timing chain cover seal [aka sear0 Triumph 3
T TR4/4A Early TR4 - Timing Cover Oil Seal Triumph 3
rodesmg oil seal on timing cover== need help Spridgets 5
hondo402000 TR6 TR6 timing cover seal and gasket fix Triumph 7
Brosky Timing cover seal project Triumph 6
MGTF1250Dave Speedi-sleeve for Timing Cover Seal Triumph 15
rodesmg oil seal on timing cover Spridgets 2
G Timing cover crankshaft seal MG 15
J Next project:: timing cover gasket and crank seal MG 2
M 1275 Timing Cover Vent Spridgets 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
A Timing cover access Spridgets 6
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
KVH General Tech Timing Cover Gasket Flub Up Triumph 4
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
C Wanted Timing gear cover 1275 Spridgets Classified 2
B TR2/3/3A Timing chain cover goop location Triumph 4
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S TR2/3/3A timing chain cover and woodruff key Triumph 4
DanLewis Looking for a good timing chain cover Spridgets 1
D timing cover Spridgets 11
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
Dudly Sump and timing cover gaskets Triumph 1
TulsaFred Leaking timing cover Spridgets 15
J TR6 tr6 timing cover removal Triumph 3
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
bugedd Tips on timing cover install Spridgets 4
bugedd Timing Cover Needed Spridgets 0
K TR2/3/3A The goop on the TR3 timing cover Again? Triumph 3
6 timing chain cover Triumph 4
bugedd Timing Cover service Spridgets 1
bugedd Anyone have a timing chain cover? Spridgets 10
PeterK TR4/4A TR3-4A timing cover tensioner Triumph 9
Bruce_B Where does hose from timing cover go? Spridgets 6
KVH Timing Cover Gasket Replacement Triumph 4
glemon TR5/TR250 Front Timing Chain Cover TR250/6 Triumph 6
E TR6 TR6 Timing Cover Fasteners Triumph 7
