oil seal on timing cover
rodesmg
Member
my oil seal is leaking on timing cover, do i need to pull the engine, or can it be done by taking out the radiator. is it a tough job. thanks
it can be done in the car, you will need to jack up the engine in order for the crank pulley to clear the rack, or remove the rack. not to bad of a job, since your going there a new chain and sprockets and tensioner would probaly be a good idea.
mark
ThomP
Often not only is the seal bad, but the pulley is galled or scored from the seal. If your pulley surface looks bad, you can repair it by installing a spedisleeve or redisleeve over the bad spot.
RJS TR4/4A Timing Chain Oil Seal Triumph 6
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
JFS General MG Timing Cover Oil Seal MG 7
RJS Timing chain oil seal Triumph 12
R Timing cover oil seal MG 3
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
T TR4/4A Early TR4 - Timing Cover Oil Seal Triumph 3
rodesmg oil seal on timing cover== need help Spridgets 5
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
W Crankshaft Oil Seal Austin Healey 3
EWD TR6 Transmission Oil Seal Triumph 13
JFS TR6 Rear Oil Seal? Triumph 1
B BJ8 Half-Shaft Oil Seal Austin Healey 5
D TR2/3/3A Front Oil Seal Triumph 12
K TR2/3/3A Front hub oil seal Felt? Triumph 1
J Rear Oil Seal Kit - Spring Austin Healey 9
D Oil Filter Bolt Seal Austin Healey 2
drooartz Rear wheel hub oil seal Spridgets 6
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
RickPA Need help installing steering idler oil seal Austin Healey 6
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
GTP1960 TR2/3/3A Resurrected an old question re: removing old style oil seal Triumph 8
C Oil Seal Removal from Idler Arm? Need Help Austin Healey 4
mcmillal TR4/4A Pinion Oil Seal Replacement Triumph 10
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
C new engine - oil pressure blowing filter seal Austin Healey 12
S Rear crank seal oil leak BN2 Austin Healey 20
B Rear Wheel Bearing Oil Seal Spridgets 7
V Oil seal part number? Austin Healey 2
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
Crankshaft Oil pan gasket seal Triumph 10
F More oil leaking...rear seal? Triumph 3
V TR2/3/3A TR3A Front Oil Seal Triumph 3
A Rear Axle Oil Seal Spridgets 2
memphis Gearbox Oil Seal Austin Healey 9
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
T steering box oil seal Austin Healey 4
Gliderman8 Front oil seal HELP with..... Triumph 28
