TR2/3/3A Resurrected an old question re: removing old style oil seal
GTP1960
[h=2]Re: Which way does the TR3 front crankshaft oil seal face?[/h]
I found this older thread that I have a question about , as I am re-sealing my timing cover, etc.
Originally Posted by AHS
I've got a new front crankshaft oil seal but I'm not sure which way it should face. One side is a tight fitting sealing ring, wrapped with a tensioning spring, while the other side is a very loose fitting wiper that barely touches the pulley surface.
Unfortunately the original one was of a very different design and isn't any help. Does anyone have definitive info on this?
Thanks,
Andy
I am in the exact same place Andy was in 3/2013. ( installing the newer, different design oil seal), however I need advice on removing the old metal flange type oil seal.
I don't want to tear anything up I might need.
i'm tempted to just pry it out, but I would appreciate input, from those who know.
Thx!​
charleyf
My Harbor Freight puller --the one shown in the picture--lasted less than two minutes. It broke where the screws are in the handle just below the head. The head is a good design the handle is to cheap to take any pressure.
Charley
GTP1960
GTP1960
Charley,
the customer reviews were mixed on this puller. Some success & some instant failures.
(I've noticed a lot of hit & miss tools @ HF).
So I took my cover over to HF & asked the guy if I could try it first before I buy?
he said "OK"; I Did ; it broke.(maybe I was using it wrong, but I doubt it)
it seems that an old English metal bound oil seal was just more than a match for new Chinese steel pry bar.
i tapped it out with a narrow screwdriver & a hammer.
thx for your comment.
sp53
I love that story and wish I could have been there to see it. I use a good heavy screw driver and flip the cover so the gasket side is down and with screw driver hook some of the meat/metal of the old seal and drive it down and out with a hammer. That said, a well-made pry pull would work also. However, I used a high quality pry puller on a differential seal and broke the puller and basically had to use a side hammer and some caveman tools.
Geo Hahn
...asked the guy if I could try it first before I buy?
he said "OK"; I Did ; it broke...
Brilliant. I also saw those reviews that show your experience is a common occurrence.
At a glance those reviews seemed fairly recent -- I bought my HF seal puller about 7 years ago and have used it for 3 pinion seals and a timing chain cover w/o a problem. I'm enough of a ham-fisted mechanic that if it was going to break I would have found a way. Perhaps they have changed suppliers and the current version is inferior. Guess I'd better stop suggesting it.
Geo Hahn
I got curious and went out to the garage and took a look at mine. Appears they changed the design (and ruined a useful tool):
Mine (purchased in 2009):
What they sell now:
GTP1960
GTP1960
I am old enough to remember when mfg. Philosophy ( & business & engineering design education) was geared to stive to make things last as long as possible.
"Planned obsolesence" was poo-pu'ed in the noble halls of higher education.
Now I believe you can get a PHD in how to make fast turn junk, for fun and profit.
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
K TR2/3/3A Old school penetrating oil? Triumph 24
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S TR2/3/3A On those old original coils Triumph 2
D never throw old parts away.... Austin Healey 7
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
JimLaney Liquids for 50 + year old Sprite Spridgets 5
