Sump and timing cover gaskets
Dudly
Hope to replace gaskets on sump and timing cover, also have oil seal. I'm going to do this with the motor in place.
Any suggestions for a successful outcome ?
Geo Hahn
You might mention what TR this is in regard too.
Lots of techniques for this -- I use 'copper' RTV on the pan/cover and press the gasket against it aligning and clearing the holes of RTV with a bamboo skewer. Then I put that arrangement gasket side down on a sheet of glass.
I just grab a big picture off the wall and use that.
Once dry (like overnight) I clean off the excess RTV (careful application in the first place minimizes the excess) so no 'noodles' remain to get into the oil later.
I then use Hylomar on the gasket and the machined surface of the engine.
Helps to verify the flatness of the stamped parts beforehand as prior over-enthusiastic tightening may have caused the hole area to dimple. I use a body hammer and dolly to flatten any dimpled holes.
Tightening is of course done is a criss-cross manner. Some use some sealant on the threads of the studs/bolts to reduce the chance of seepage there.
WHT Oil Sump Question For Dougie Austin Healey 0
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
Lin Oil sump sealant question Spridgets 0
Lin Oil sump torque value? Spridgets 3
Walter74 Oil sump AH spares Austin Healey 5
M Sump Plug Austin Healey 26
M Sump Installation Spridgets 2
F Sump Gasket Question Austin Healey 15
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
Lin Oil sump gasket replacement Austin Healey 31
Healey Nut 3000 oil sump pans Austin Healey 16
R Proper Aluminum Sump Installation Austin Healey 13
Michael Oritt Strange debris found in sump Austin Healey 19
J TR6 Thrust washers in sump Triumph 4
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
TomMull Sump pan with no baffle? Triumph 2
abarth69 Dry Sump BMC Engine Spridgets 3
T XK Engine Sump Pan Jaguar 9
OZ_BN1 Sump Plug Austin Healey 0
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
Westfield_XI Evacu-sump installation Spridgets 5
Westfield_XI Evacu-sump installation questions Spridgets 4
newmexTR3 TR 2/3/4 aluminum sump gasket Triumph 4
B Oval sump washer orientation Austin Healey 2
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
2wrench Help. Leak from sump cover on bottom of J-OD Triumph 31
Scott_Hower MGB MGB sump removal .. must I drop the xmember? MG 13
J Can I drive with dipstick pipe in sump? Spridgets 6
philman Wedge TR8 oil sump pans Triumph 2
TRclassic3 TR2/3/3A TR3 Oil Sump Gasket Question Triumph 3
M XK 140 Sump color Jaguar 4
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
cjm dry sump system Triumph 8
dkj313 MGB Sump Gasket 76 MGB MG 5
J TR4/4A Aluminum Sump made for TR3-TR4? Triumph 15
Lin Oil Sump gasket dressing [sealant] Austin Healey 3
Dave Russell Experience installing new oil sump Austin Healey 2
bighly Magnetic sump plugs / tranny plugs Austin Healey 0
P Oil sump capacity Austin Healey 7
bighly Sump [does 1 size fit all?] Austin Healey 1
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
