dry sump system
G
Dry sumps have been rigged on every engine known. Just big bucks. Have you tried RevingtonTR or CambridgeMotorSports on your side of the pond?
Bill
G
[ QUOTE ]
"big bucks" is my spits' middle name!
[/ QUOTE ]
You mean "big pounds" don't you?
Bill
mikespain
Hi ,try looking at the online catalogues of one of the following -DEMON TWEEKS,BURTON PERFORMANCE,OR RIMMER BROTHERS ALL IN THE UK
abarth69 Dry Sump BMC Engine Spridgets 3
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
drooartz MGB Any risk rolling car on dry bearings MG 4
F Heater valve/tap gasket- Install dry? Austin Healey 10
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
B dry fitting the bonnet 57 Triumph 1
G TR6 How dry does your TR6 Hard Top keep you? Triumph 2
dougie PNW Dry Winter Weather Austin Healey 7
TR6oldtimer Looking for a source for Dry Vinyl Harness tape Triumph 5
tweety Dry dashpot and backfiring. Spridgets 8
R dry rot in tires Austin Healey 4
Jim_Gruber Rubber Side Cover Gaskets-Install Dry? Spridgets 1
Jim_Gruber Intake Manifold Gasket - Dry or coated with ? Spridgets 4
T Dry as a bone Triumph 7
aeronca65t Dry Lakes Belly Tanker Other Cars 4
dklawson Spitfire Spitfire Dry Engine Starts-Need Smoke Explanation Triumph 3
J touch up paint, . dry time affect on color Austin Healey 11
NutmegCT TR2/3/3A new water pump dry run - TR3A Triumph 9
Nunyas Dry fitted the HS6 today.. MG 30
C Dry oil filter Triumph 20
bcliff Hydrolastic/dry conversion British Motor Corp 3
jaybird Out to dry MG 15
Bret Finally Dry Tools! Restoration & Tools 0
T TR4/4A TR4A Fuel Starvation problem: Dry float bowls Triumph 8
G Filling a completely dry cooling system.... Triumph 13
G TR6 Ultra-dry TR6 Triumph 4
J Heat and dry ice to remove hail damage Triumph 2
B FAST & EASY CAR DRY METHOD Restoration & Tools 2
WHT Oil Sump Question For Dougie Austin Healey 0
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
Lin Oil sump sealant question Spridgets 0
Lin Oil sump torque value? Spridgets 3
Walter74 Oil sump AH spares Austin Healey 5
M Sump Plug Austin Healey 26
M Sump Installation Spridgets 2
F Sump Gasket Question Austin Healey 15
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
Lin Oil sump gasket replacement Austin Healey 31
Healey Nut 3000 oil sump pans Austin Healey 16
R Proper Aluminum Sump Installation Austin Healey 13
Michael Oritt Strange debris found in sump Austin Healey 19
J TR6 Thrust washers in sump Triumph 4
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
Dudly Sump and timing cover gaskets Triumph 1
