Dry dashpot and backfiring.
tweety
'79 midget with z-s carb.... California car
The car was up on blocks for a couple of weeks while I fitted a gear reduction starter.... That works great.
The car was backfiring (at the carb)and sputtering after shifting from second to thrid and third to fourth.
I discovered there was no oil in the dashpot so I filled it up. The backfiring and sputtering is MUCH better now, but it will still do it (esp in 3rd) right around 2K rpm. Overall the car's very sluggish.
I'm thinking that the backfiring either damaged the carb or totally messed up the settings.
Any words of wisdom?????
dklawson
It's doubtful that anything has been damaged or knocked out of adjustment by the backfiring. However, if the rubber diaphragm is old though, I would check to make sure that it is intact. The ZS carbs have a reputation for loosing their dashpot oil.
I found the same backfiring and stumbling behavior when I had 10W30 oil in the damper. I changed to 20W50 and things were much improved. If the oil you put in was thin, you may benefit from trying a heavier oil before looking at any major adjustments or carb tuning. I was surprised to see on one of John Twist's (University Motors) YouTube videos that he encouraged his customers to run 90W oil in the carb damper. That's much thicker than the 20W oil our cars carbs' probably left the factory with.
Roger
Bronze
I agree with nearly all the above, but note that 90W oil is probably gear oil, which has a different viscocity scale than engine oil, and is closer to 30w.
tweety
tweety
I used the SU/Zenith Dashpot oil sold by Moss and VB
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=31273&SortOrder=1
I'll check the diaphragm and replace the oil with something heavier.
I would really love to pitch the ZS but then I would not pass smog. It's tested every two years which really isn't the end world if a change out is needed..... But my test is due in a couple of months.
What I really want to do is replace the engine all together. Maybe drop in a 1275 and tranny. I would have to be sure that I can get it certified as a pre '76 engine by the state..... No more smog checks then!
Right now I just want it to go.
nomad
Tweety: Move out here to So Dak. Our governor and legislature love "gross pollution". Trying to get one of the biggest oil refinerys ever built in this country with virtually no pollution control. Also a huge coal powerplant.
KA.
Hairyone
I had problems with my HIF44 carb loosing it's oil, (I cut the tube down to get it inside my Bugeye hood).
My solution, find some rubber tube that fits tightly the tube, cut a piece 1/8" long, slit it along it's length & slide it around the damper rod, then wedge it inside the dashpot tube. It's a little awkward to get in, but I don't loose any oil.
ralph_s
You may be set to lean, that will cause a backfire. Had the same problem w/ mine and a timing & carb adjustment fixed the problems. I use 30W in mine w/o any problems and it gets cold in PA. Had to buy the "special" tool to adjust the carbs. IMHO, I'll take SU's anyday!!!!
tweety
tweety
took a look tonight. The diaphragm was fine. Filled it with 80 90 gear oil. No more backfiring or sputtering.
It's still a little on the sluggish side, but I think that's some fine tuning as the idle speed seems low.
Thanks for the advise, I would never be able to own a LBC without your help
ralph_s
Pull the plugs and take a look at the color, that will tell you quite a bit about the carb setting & running condition. Start the engine & run at a high RPM or take it for a spin. Don't check after a long idle or they won't reflect the running condition.
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
drooartz MGB Any risk rolling car on dry bearings MG 4
F Heater valve/tap gasket- Install dry? Austin Healey 10
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
B dry fitting the bonnet 57 Triumph 1
G TR6 How dry does your TR6 Hard Top keep you? Triumph 2
abarth69 Dry Sump BMC Engine Spridgets 3
dougie PNW Dry Winter Weather Austin Healey 7
TR6oldtimer Looking for a source for Dry Vinyl Harness tape Triumph 5
R dry rot in tires Austin Healey 4
Jim_Gruber Rubber Side Cover Gaskets-Install Dry? Spridgets 1
Jim_Gruber Intake Manifold Gasket - Dry or coated with ? Spridgets 4
T Dry as a bone Triumph 7
aeronca65t Dry Lakes Belly Tanker Other Cars 4
dklawson Spitfire Spitfire Dry Engine Starts-Need Smoke Explanation Triumph 3
J touch up paint, . dry time affect on color Austin Healey 11
NutmegCT TR2/3/3A new water pump dry run - TR3A Triumph 9
Nunyas Dry fitted the HS6 today.. MG 30
C Dry oil filter Triumph 20
bcliff Hydrolastic/dry conversion British Motor Corp 3
cjm dry sump system Triumph 8
jaybird Out to dry MG 15
Bret Finally Dry Tools! Restoration & Tools 0
T TR4/4A TR4A Fuel Starvation problem: Dry float bowls Triumph 8
G Filling a completely dry cooling system.... Triumph 13
G TR6 Ultra-dry TR6 Triumph 4
J Heat and dry ice to remove hail damage Triumph 2
B FAST & EASY CAR DRY METHOD Restoration & Tools 2
Got_All_4 TR6 Dashpot seal Triumph 1
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
M Dashpot oil question Triumph 30
E Bugeye HIF6 Dashpot Cap Spridgets 12
NardisCNC DASHPOT OIL QUESTIONS??..... Spridgets 20
V Dashpot oil disappearing! Spridgets 29
T How much dashpot oil leakage is normal Triumph 14
Ed_K Dashpot oil viscosity Austin Healey 15
T Carb Dashpot Oil Level Spridgets 6
M Vanishing dashpot oil? Austin Healey 3
J dashpot oil Triumph 23
Woodie dashpot oil Spridgets 9
Baz Dashpot... Spridgets 2
bobh Stromberg dashpot O-ring Size ? Triumph 0
vping Results of Low Dashpot oil MG 11
Y Dashpot oil consumption Austin Healey 4
Lin HD8 carb dashpot height Austin Healey 1
D Dashpot Oil Spridgets 10
77MidgetMkIV Dashpot Damper / DP Oil question Spridgets 8
S Dashpot Oil Triumph 4
