Hi,
TRF might get one of these, but I'm sure it will cost more than $379 now. The last price I saw was over $500. I had ordered one from them, but it was a four or five *year* backorder! I'm not kidding, unfortunately.
Instead you might want to try Ken Gillanders at British Frame and Engine (
www.britishframeandengine.com). Might be only a little bit cheaper, but more importantly he can usually get the part to you in a reasonable time.
I believe he offers a choice of four different sumps:
You can get the deeper sump, which is most similar to the factory option, and I think is what was described above. This is probably the best one to improve cooling, but more vulnerable because it hangs below the frame rails.
Or, there is a short "race" sump that is better for ground clearance and less exposed. It sits about flush with the frame rails and would be my personal choice.
And, I think either of those models can be bought in black or natural cast aluminum finishes.
The short "race" sump requires a bit of modification to the oil pump, but everything necessary is included with the kit.
I believe all the alloy sumps come with windage trays.
The aluminum itself will transfer heat better than steel, but overall the thicker walls don't make for a great deal of improved cooling. I think the primary improvements will be a more rigid bottom end and better sealing.
If your goal is better cooling without fans and/or oil cooler, or to supplement those accessories, Revington TR sells a modified steel sump that has tubes installed lengthwise to allow airflow right through the sump pan itself and increase the exposed surface area for heat exhange. Sort of a neat idea, with less "to go wrong" than might be the case with an external oil cooler or added electric fan. But, done right there should be matching holes cut in the frame cross member in front of the engine, to direct as much air as possible through the tubes in the sump.
p.s. I just took a look at Ken's website (link above) and notice he also offers magnesium sumps in either black or natural finish. Magnesium appears to be only be available in one size, I'm guessing the deeper version, might want to clarify that with Ken. Overall, the prices seem to be a bit lower than in the recent past, so maybe some new suppliers have come on the scene.
