TR2/3/3A Repairing thin aluminum sheet metal like the grill.
TRTEL
Except in this case I need to effect some repair on both aluminum drip rails for a hardtop. The metal is just a bit less than .040 in thickness. I tried searching the archive but only found a reference to light gauge mig welding and don't have a good feeling for using that. Has anybody got experience with the soldering type alloys on the market. I not expecting to be able to polish any of this, but rather just to create a clean outline of what was originally there. There is one hole about 3/8 x 3/16 to fill and would try cutting a similar thickness of sheet metal to fill the void. The front edges of both are ragged and need to be built out some how. Remaining anodizing will have to be removed. Any ideas greatly appreciated.
Darrell_Walker
How about using JB Weld, or I think they have a putty-like version to build it up? If you are already going to have to mess up the surface, you could then paint the whole thing.
CJD
I have never had luck working anodized aluminum. I'd lean towards working a new strip of .040" aluminum to fit. Of course, if you plan to paint...the filler Darrell mentions would be a good option to save effort.
T
TRTEL
Darrel and John, You've just provided some inspiration. Hadn't thought about adding another layer, but it could work here quite well by just adding a fresh surface of maybe .010 aluminum to the flat drainage surface of the channel. Gluing it on like a laminate with JB weld. I'm sure a sheet metal shop could crank out two perfect strips of exact size. The outer edge would be 95% covered/hidden by the outer curve of the channel which looks okay. the inner edge would be hidden against the rubber water seal strip. And I thank you both!
WiscTR
We all love JB weld, but you might check out double-sided tape from 3M. Very good adhesion and allows some flexing and movement although I am not sure how important that is in your application.
martx-5
I've used aluminum brazing rods from Alumiweld. https://www.alumiweld.com/ Basically, they are zinc rods. Zinc has a lower melting point then aluminum. You only need a propane torch and I believe a stainless steel wire brush for prep. I repaired holes in my dash cappings with the stuff. Very easy to use and looks and acts just like aluminum so it can be sanded, filed or machined if necessary.
D TR2/3/3A repairing broken hardboard seatback Triumph 8
LAW75 Repairing Windscreen Scratches Austin Healey 10
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Repairing BE Washer Pump Spridgets 5
M TR2/3/3A Repairing a flat tire on TR3 Triumph 15
Triumph_TR4_Girl TR4/4A Repairing Chrome Bumpers TR4 Triumph 2
F Repairing the battery master switch Austin Healey 3
pkmh Repairing Original Fractured Steering Wheel Austin Healey 10
PeterK Repairing cast iron manifold studs Triumph 16
S TR2/3/3A Repairing a tr3 heater? Triumph 14
64Elan Repairing plexiglas scratches Restoration & Tools 9
P GT6 GT6 Repairing Rust in Rear Quarter Triumph 8
T Recovering & repairing a Bugeye dashboard - tips? Spridgets 25
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
longbridgehealey repairing window curtains Austin Healey 0
G Installing/Repairing Carpet Restoration & Tools 1
Trevor Jessie Repairing a dual gauge, follow up Spridgets 4
C Repairing Exhaust Manifold Austin Healey 13
G Repairing rock chips.... Triumph 2
R Repairing Paint Chips Austin Healey 8
Bruce Bowker repairing a steering wheel Other British Cars 14
T Repairing a dual water temp / oil gauge Spridgets 1
W Repairing split in metal water pipe? Triumph 3
T TR2/3/3A Question on spacer in Moss thin belt/damper conversion kit 837-508 Triumph 3
angelfj1 Valve Cover Gasket - Too Thin? Triumph 15
prb51 TR2/3/3A TR3 thin belt conv and damper Triumph 4
A Paper thin hub gasket- will it work? Austin Healey 6
blacknite3 Heater is in, antifreeze is brown and oil is thin! MG 7
Moose33 seeking out a thin intake manifold.. MG 3
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
