Repairing Paint Chips
Ray Smith
Anyone have any good suggestions for reparing paint chips. My "new" healey has some chips in the paint that I would like to repair. My attempts at repainting chips with the little touch-up applicators has been terrible.
Ray
rulle7
Ray, can't answer your question, but am eagerly awaiting a reply since I've got the same issue with my Midget.
Someone will be along shortly, I'm sure. /ubbthreads/images/graemlins/cheers.gif
Depending on color, I've had pretty good results using the following products on my BMWs.
Using the touch up paint, fill in the crater gradually (layer by layer, letting each layer dry thoroughly) until the surface of the chipped area is higher than the surrounding area. Let this dry for several days.
Now get yourself some Langka (www.langka.com) and follow the directions.
The repaired chips on the metallic black car are completely invisible. The gray car doesn't lend itself so well, while certainly better than seeing light colored primer, you can still see them in certain light. More a function of the color match of the touch up paint than the process.
All in all, the Langka does what it claims to do, can't ask any more than that from a product.
Skip & Lynne
Ray try this.
Step 1. Use the touch up bottle and caot by coat fill the chip untill it is higher than the surrounding paint. Let each coat dry before you apply the next one.
Step 2. Use some 1500 or 2000 grit sandpaper and GENLY wet sand the chipped area down untill it is flush with the surrounding paint. Don`t worry if you scratch the surrounding area just don`t cut through the color coat.
Step 3. Get a variable speed buffer (Harbor Freight Tools) with both a wool pad and a soft foam pad.
Step 4. Use a medium buffing compound with the wool pad and buff the sanded area. DO NOT BURN THE PAINT. Let the buffer do the work gently.
Step 5 Use a fine compound with the foam pad and finish the buffing and finish off with a hand coat of good wax and then swirl remover and the results will amaze you. Skip
Geo Hahn
If I may offer a Step 1.5 -- I use a single-edge razor blade with pieces of masking tape over each end of the edge of the blade, leaving a gap of bare blade about a half inch or slightly more than the width of the chip.
This can then be pushed along to shave the excess paint to a level very close to the surrounding paint. Then on to Step 2 which will not take much sanding.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
I agree with Randy. No sanding, shaving, polishing. Langka is great.
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Whew, those guys work too hard! Ive got too many projects going on to spend that much time on paint chips /ubbthreads/images/graemlins/crazyeyes.gif
D TR2/3/3A repairing broken hardboard seatback Triumph 8
LAW75 Repairing Windscreen Scratches Austin Healey 10
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Jim_Gruber Repairing BE Washer Pump Spridgets 5
M TR2/3/3A Repairing a flat tire on TR3 Triumph 15
Triumph_TR4_Girl TR4/4A Repairing Chrome Bumpers TR4 Triumph 2
F Repairing the battery master switch Austin Healey 3
pkmh Repairing Original Fractured Steering Wheel Austin Healey 10
PeterK Repairing cast iron manifold studs Triumph 16
S TR2/3/3A Repairing a tr3 heater? Triumph 14
64Elan Repairing plexiglas scratches Restoration & Tools 9
P GT6 GT6 Repairing Rust in Rear Quarter Triumph 8
T Recovering & repairing a Bugeye dashboard - tips? Spridgets 25
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
longbridgehealey repairing window curtains Austin Healey 0
G Installing/Repairing Carpet Restoration & Tools 1
Trevor Jessie Repairing a dual gauge, follow up Spridgets 4
C Repairing Exhaust Manifold Austin Healey 13
G Repairing rock chips.... Triumph 2
Bruce Bowker repairing a steering wheel Other British Cars 14
T Repairing a dual water temp / oil gauge Spridgets 1
W Repairing split in metal water pipe? Triumph 3
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
