Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Just wondering how well the paint thickness testers work in detecting the amount of body filler under the paint. Any recommended units? Something between the professional and HF.
There are high tech units you can buy for $$$$$$.
Most non-pros use a magnet with a protective coating and can estimate bondo with it.
You can compare strength with a known un-bondoed area.
Only the high end painters use the expensive instruments.
Expensive versions can find different layers, the normal ones only the total thickness (from metal up)
I use a Paintdetective when polishing with the machine
Ideal would be having a new paintjob and the painter using it between layers
That would be the only way to know the thickness of the outer layer.
The cheaper Amazon stuff is as usefull as a magnet covered in clingfilm
Would have thought so to, but looked on Eastwood's site yesterday and didn't see one. I guess what I was asking about was more of a body filler detector/gauge, rather than a paint thickness gauge.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
