Oil Sump gasket dressing [sealant]
Lin
What is the recommended sealant for this purpose? I am planning on using hylomar, but before I do I thought I would check with the authorities.
Lin
1960 BT7 in restoration
1959 Bugeye
Geo Hahn
I use Blue Hylomar with good results (provided you have a nice flat surface on the oil pan). I would not use anything that sets up (e.g. RTV sealant) lest a noodle of it squirts inward and finds its way into the oil.
Dave Russell
Yoda - R.I.P
I have best luck gluing the gasket to the pan surface with contact cement, holds it in place during the fitting, & blue Hylomar on the engine pan rail side of the gasket. Ditto on the RTV.
Lin Oil sump gasket replacement Austin Healey 31
TRclassic3 TR2/3/3A TR3 Oil Sump Gasket Question Triumph 3
WHT Oil Sump Question For Dougie Austin Healey 0
Lin Oil sump sealant question Spridgets 0
Lin Oil sump torque value? Spridgets 3
Walter74 Oil sump AH spares Austin Healey 5
Healey Nut 3000 oil sump pans Austin Healey 16
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
philman Wedge TR8 oil sump pans Triumph 2
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
Dave Russell Experience installing new oil sump Austin Healey 2
P Oil sump capacity Austin Healey 7
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
