Oval sump washer orientation
B
BobHorvath
I never seem to be able to properly search these forums. I assume the photos in the engine manual are correct in placing the long axes of these oval washers parallel to the crank. Question is the convex surface facing up against the sump?
Keoke
BobHorvath said:
I never seem to be able to properly search these forums. I assume the photos in the engine manual are correct in placing the long axes of these oval washers parallel to the crank.--Yes :yesnod:
Question is the convex surface facing up against the sump?--The washer is probably bent from over tightening straighten it out or replace with new.
-----Keoke
vette
Hello Bob, I'm not really sure that the convex or concave part being up or down makes a whole lot of difference. But I would either hammer them flat or use the concave part up. the big deal is what you are using for gasket and sealing. There are so many variables here i'm sure there are as many opinions. One thing is you should not have to torque or overly tighten these screws. A good sealing compound and the right gasket and just snug them up. The sealing compound doesn't what to be squeezed out of the joint.
M TR4/4A Difference between two Oval Air Filters Triumph 3
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
Patrick67BJ8 BJ8 Grille Oval Surround "silver paint" needed Austin Healey 3
M Need Oval-head chromium-plated screws for "Mk IV" Jaguar 26
WHT Oil Sump Question For Dougie Austin Healey 0
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
Lin Oil sump sealant question Spridgets 0
Lin Oil sump torque value? Spridgets 3
Walter74 Oil sump AH spares Austin Healey 5
M Sump Plug Austin Healey 26
M Sump Installation Spridgets 2
F Sump Gasket Question Austin Healey 15
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
Lin Oil sump gasket replacement Austin Healey 31
Healey Nut 3000 oil sump pans Austin Healey 16
R Proper Aluminum Sump Installation Austin Healey 13
Michael Oritt Strange debris found in sump Austin Healey 19
J TR6 Thrust washers in sump Triumph 4
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
Dudly Sump and timing cover gaskets Triumph 1
TomMull Sump pan with no baffle? Triumph 2
abarth69 Dry Sump BMC Engine Spridgets 3
T XK Engine Sump Pan Jaguar 9
OZ_BN1 Sump Plug Austin Healey 0
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
Westfield_XI Evacu-sump installation Spridgets 5
Westfield_XI Evacu-sump installation questions Spridgets 4
newmexTR3 TR 2/3/4 aluminum sump gasket Triumph 4
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
2wrench Help. Leak from sump cover on bottom of J-OD Triumph 31
Scott_Hower MGB MGB sump removal .. must I drop the xmember? MG 13
J Can I drive with dipstick pipe in sump? Spridgets 6
philman Wedge TR8 oil sump pans Triumph 2
TRclassic3 TR2/3/3A TR3 Oil Sump Gasket Question Triumph 3
M XK 140 Sump color Jaguar 4
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
cjm dry sump system Triumph 8
dkj313 MGB Sump Gasket 76 MGB MG 5
J TR4/4A Aluminum Sump made for TR3-TR4? Triumph 15
Lin Oil Sump gasket dressing [sealant] Austin Healey 3
Dave Russell Experience installing new oil sump Austin Healey 2
bighly Magnetic sump plugs / tranny plugs Austin Healey 0
P Oil sump capacity Austin Healey 7
bighly Sump [does 1 size fit all?] Austin Healey 1
K TR2/3/3A Picture of the Zinc washer. Triumph 3
W Glass Washer Bottle Lids Austin Healey 0
