Evacu-sump installation questions
Westfield_XI
I am getting ready to install a crankcase evacuation system in lieu of a traditional breather system on my A-series engine. Does anyone know how far into the exhaust header the fitting should extend? Also does it matter how far from the exhaust port it gets welded in? Should it be below where the long and short branches join?
Which port under #4 exhaust should I use? There are two there... Is there a cap for the valve cover that is airtight, mine has vents in it?
Billm
Don't know how far to put it in but just be sure to use a check valve in-line to prevent flame/fire from traveling up into the crankcase (Ford Fairmont straight6 around 1980 had one).
BillM
Westfield_XI
Westfield_XI
You have to use a check valve to allow the low pressure waves to create a vacuum in the crankcase so no worries there.
It needs to be at the collector or beyond, if your block has the drilling for a mech fuel pump (not all A series engines have these, some are just blank there) you can get a nice baffled aluminum piece from Mini Mani that goes where the mech. fule pump blanking palte goes, that has a NPT tapping in it, this is taking the crankcase pressure directly from the source, and the best place to do it.
Westfield_XI
Westfield_XI
Where the heck is this fuel pump mounting block? I have a Carter electric pump and have no idea where the original fuel pump was located..... What if I don't have the drilling for a fuel pump? Is there an alternate location?
There are two plugs in the block under #4 exhaust port, is one of these suitable? Which one?
Any tips on sealing up the dipstick? I was thinking that I could just use a rubber plug like a cork and keep the actual stick in the car for use at gas stations.
Does anyone make an oil filler cap that is unvented? One that will fit onto the stamped steel valve cover? If I must I can get a different valve cover from a V-8 or other car in a junkyard and remove the cap boss from that one and weld it to mine.
Westfield_XI Evacu-sump installation Spridgets 5
WHT Oil Sump Question For Dougie Austin Healey 0
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
Lin Oil sump sealant question Spridgets 0
Lin Oil sump torque value? Spridgets 3
Walter74 Oil sump AH spares Austin Healey 5
M Sump Plug Austin Healey 26
M Sump Installation Spridgets 2
F Sump Gasket Question Austin Healey 15
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
Lin Oil sump gasket replacement Austin Healey 31
Healey Nut 3000 oil sump pans Austin Healey 16
R Proper Aluminum Sump Installation Austin Healey 13
Michael Oritt Strange debris found in sump Austin Healey 19
J TR6 Thrust washers in sump Triumph 4
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
Dudly Sump and timing cover gaskets Triumph 1
TomMull Sump pan with no baffle? Triumph 2
abarth69 Dry Sump BMC Engine Spridgets 3
T XK Engine Sump Pan Jaguar 9
OZ_BN1 Sump Plug Austin Healey 0
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
newmexTR3 TR 2/3/4 aluminum sump gasket Triumph 4
B Oval sump washer orientation Austin Healey 2
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
2wrench Help. Leak from sump cover on bottom of J-OD Triumph 31
Scott_Hower MGB MGB sump removal .. must I drop the xmember? MG 13
J Can I drive with dipstick pipe in sump? Spridgets 6
philman Wedge TR8 oil sump pans Triumph 2
TRclassic3 TR2/3/3A TR3 Oil Sump Gasket Question Triumph 3
M XK 140 Sump color Jaguar 4
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
cjm dry sump system Triumph 8
dkj313 MGB Sump Gasket 76 MGB MG 5
J TR4/4A Aluminum Sump made for TR3-TR4? Triumph 15
Lin Oil Sump gasket dressing [sealant] Austin Healey 3
Dave Russell Experience installing new oil sump Austin Healey 2
bighly Magnetic sump plugs / tranny plugs Austin Healey 0
P Oil sump capacity Austin Healey 7
bighly Sump [does 1 size fit all?] Austin Healey 1
A MGB Seat Cover Installation MG 1
Sarastro TR4/4A Convertible top installation problem Triumph 12
D BJ8 Top Installation Detail Austin Healey 3
zoohow BN4 Top Frame Installation Austin Healey 1
R MGB side chrome installation MG 4
P Alternator Installation Pic Austin Healey 4
