Where does hose from timing cover go?
Bruce_B
I've got a 1275 engine in my BE. The timing chain cover is the one with the can attached to it with a pipe at the top.
Do I attach that to an intake opening on the intake manifold? Do I put a hose on it to drop on the ground? What about attaching it to one of those chrome oil breather?
I also drilled a hole into the block where the mechanical gas pump would go if I had one. Right now it's blocked off should that also go into the manifold or into a chrome oilbreather?
Thanks...I'll get this thing running just in time for snow.
Glen_B
It should go the the intake manifold but will suck up tons of oil if you don't put a restriction in the line or use one of the "flyng saucer" gulp valves that belong on a 1275.
Glen Byrns
asoupley
Glen Byrns
Is this where you could use a newer PCV valve instead of the pancake looking thing?
-Tony
jhorton3
I've tried the newer PCV valves and an oil catch can to prevent oil vapor from sucking into the intake, and I still get smoke after the motor warms up. It doesn't happen all the time, just about 3 miles worth of driving after the motor comes to normal temperature. I'm about to strip all that out and go back to the original pancake PCV configuration. If that doesn't work I'll rent it to the local Orkin man during mosquito season.
Bruce_B
Bruce_B
I did run the engine with the can hooked up into the intake. There are no longer any mosquitos within 1/4 of my house. Does it have to be hooked up at all? Any one have pictures?
GeeBee1
Bruce, you have got me laughing, the first time I ran my BE with a 1275 I did the same thing, to the air filters.
I had mine going to the 1275 intake (original setup 1275) with the holes by the carb linkage. I didn't like the way that looked and have gone to a vented catch can on the fender well.
Thanks for the memories...
jvandyke
I don't know squat but that doesn't stop me. See if I'm on track.
If you don't attach the system to a vacuum source (intake) it doesn't "suck out" the pressure and you can have oil leaks.
Depending on the engine conditions, rings and such you might not need much "suction" to alleviate the pressure and control oil seepage.
Gulp valve/PCV controls/regulates the "suction".
In my case, 1098 without the timing cover connection, I went out of the rocker cover to the intake and restricted the size of the hole in the connection "metered orifice" instead of a PCV valve. Oil leak stopped. No discernible smoke. Probably sucking in oil to the intake but I don't notice anything bad at this point.
I'd first attach straight to the intake but reducing the opening by some means (I slipped a vaccum cap over the tip of the barbed fitting with the tip snipped off, then slid the hose over it all) down to about 1/16" diameter. Less clutter, less stuff, less cost if it works.
M TR2/3/3A Where does this screw go? Triumph 6
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
M TR4/4A Where does this attach? Triumph 7
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
Tinkerman TR2/3/3A Where oh Where does the other end go? Triumph 4
Lbp TR2/3/3A Furflex Door Seal - Where does it go? Triumph 3
J MGB Name this part? Or , where does it go? MG 9
AngliaGT 4speedDatsun B210 - Where Does it End? Other Cars 4
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
CJD Where does the oil go? Triumph 9
Got_All_4 Wedge 80 TR7 PI where does this go Triumph 7
richberman Where does this panel fit? Austin Healey 2
Brooklands Where does this part go? Triumph 8
I Does anyone know where to get some of these? Spridgets 5
Tinkerman Where Does YOUR Tube Go? Triumph 12
Newkie Where does the commision no. badge go? MG 2
F Where does this wire go ? MG 1
davidk Where does it end.... Triumph 14
Bruce_B Datun 5 speed--where does the Speedo cable attach? Spridgets 26
R BJ-7 Steady Bracket? What is it & where does it go Austin Healey 20
mjobrien Flasher for BN1 - Where does it mount? Austin Healey 8
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
tomshobby Where does it end? Triumph 24
J Spitfire '70 Spitfire MK3 - Where does this attach? Triumph 10
vping Where does this go? MG 9
Basil Where does this go? Jaguar 11
R where does all the oil go? Triumph 2
G Where does my oil pressure line connect? Spridgets 4
E Does anyone know where this XKE ended up Jaguar 6
P Where does this go? Sunbeam (Rootes) 4
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
