Sorry for all the questions, but someone else took this car apart and it's like a jigsaw puzzle putting it back together.
This is on the '57 BN4.
Today's the day to rebuild the steering box. Everything looks good in there, except for the oil seal, which I have.
The diagrams show a felt bush at the point where the steering shaft exits the steering box. I have a new Moss felt bush - a flat piece of white felt about 1/4 inch thick, but am wondering where to install it. Does it go into the bottom end of the tube that extends up to the steering wheel, between the steering shaft and the tube - tight against the bottom of the tube? That tube fits into the steering box about 1 1/2 inches.
What stops oil from leaking out between the tube and the steering box - it is not a tight fit.
Also, any tricks for installing the felt bush? How far does it go in, etc? And what oil do people use in the steering boxes, other than the special stuff sold for this? It seems that people use anything from 90 wt gear oil to #0 grease. Thoughts?
I also can't find a torque spec for the steering lever/pitman arm connection to the shaft coming from the steering box. I'm guessing about 150 ft lbs, but would appreciate an accurate number. Thanks for any help.
