TR4/4A Lower crash pads for dash....help.
malbaby
Does anyone a matching left hand lower crash pad to match the pics attached.
Alternatively, anyone selling a matching pair for RHD car with grab handle on lower left.
All the regular suppliers say not available.
Gliderman8
M
malbaby
Thanks...tried them also.
I did find one lower left pad with grab handle, but the seller wanted the equivalent of over $500 australian, cannot justify that purchase.
R TR6 TR6 Lower RT/LT Crash Pads Triumph 1
I TR6 Source for TR6 lower left and right crash pads? Triumph 12
tr6web TR6 Installing new lower crash pads - TR6 Triumph 6
Rut TR4/4A Lower crash pad Triumph 9
M TR4/4A Left lower dash crash pad. Triumph 5
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
aero3113 100 lower windshield seal Austin Healey 4
RCarr BN1 Lower Control Arms Austin Healey 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
