Timing cover crankshaft seal
GTsRFine
On a 74 B - is it possible to remove the harmonic dampener (main pulley) without removing the steering rack?
Situation - engine in car, slight oil leak behind pulley.
2nd question - can this leak be tolerated for a while or does it need immediate attention?
Oh yeah - leak rate is about 0.5 qt in 500 miles.
G
the sreering rack is so easy to pull I'd do it, and any leak can be tolerated as long as you want to keep topping up the oil
tony barnhill
Great Pumpkin - R.I.P
Steering rack will be easier to pull than everything else!
G
GTsRFine
I must be missing something Chuck.
Just looking at it... 4 bolts under the rack itself is easy, but the clamp at the steering UJoint is going to be a pain. Then there's reattachment.
If you only remove the 4 bolts at the bottom of the rack, the steering column will contact the motor mount after lifting the rack only a short distance. Will this distance be sufficient?
About the need to do the repair quickly or not... does the seal deteriorate after starting to leak?
Tom Bedenbaugh
If you just take the 4 mount bolts out of the rack it will move fowared rnough to get the pully off. One thing be sure to replace the pully(don't replace the crank bolt yet) before tightening the bolts on the timing cover, That way you will center the seal. Then remove the pully so you can get to the two bottom bolts. Also it's a good idea to skin the gasket with sealer.
MarkJ
Member
Hay Tom,
Any tricks for getting the bolt holding the front pully loose? My engine is out of the car (trans still attached). And what about the nut holding the flange on the back of the trans. I want to replace the front and rear seals on the engine and transmission before I put it back in the car.
Thanks,
Mark
G
GTsRFine
Put 2 flywheel bolts back in the end of the crank and use those as a lever point to hold the crank stationary while torqueing on the front pulley bolt. Works for me. An air impact wrench is handy also.
Can't help you with the tranny seals question.
this might sound a little scary but it worked..
oil pan off
large chunk of brass between crank and block , to hold crank from spinning. i used a piece of square stock so as to distribute load.
3/4 breaker bar and proper socket
large pipe.
use this at your own risk
good luck
Mark
iggy
Member
MarkJ:
There's also the 'rope trick'...
Remove a spark plug, feed rope into the cylinder. Reef on the nut. The rope will stop the crank from moving without damaging the cylinder.
Haven't done it on a B, but I have used it and it works.
MarkJ
Member
Thanks guys.
I have read about the rope trick, but was always to scared to try it. Afraid that I would bend a valve or something. I have taken the oil pan off and held the crank from turning but I used a 2X4.
I think I'll try putting the flywheel bolts back in the back of the crank and wedging it with a crowbar.
Tom Bedenbaugh
The 2x4 is what I was going to tell you, but the crank bolt trick would be easier if the oil pan was on. As for the tranny. I have a piece on steel stock that I drilled two holes in to match up with the D/S mountong bolts. Once it spins around and hits the floor you can break it loose, or retorque it. I also use the same piece for the rearend. Even with them in the car it will work if you make it long enough to hit the bottom pan under the car. I use them for retorqueing. My Igersol Impact makes short work of removing them.
[ 08-13-2003: Message edited by: Tom Bedenbaugh ]</p>
G
I've heard of putting a breaker bar on it and cranking the engine. (maybe from JDW?)
Tom Bedenbaugh
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>I've heard of putting a breaker bar on it and cranking the engine<hr></blockquote>
That was me, we have to do that to Alfa's, and Fiat's sometimes. Ive never had to do it to a British car because you can get an impact on them.
G
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Tom Bedenbaugh:
<hr></blockquote>
credit where credit is deserved
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
vette Timing Cover crankshaft pulley seal Austin Healey 6
M 1275 Timing Cover Vent Spridgets 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
A Timing cover access Spridgets 6
KVH General Tech Timing Cover Gasket Flub Up Triumph 4
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
C Wanted Timing gear cover 1275 Spridgets Classified 2
JFS General MG Timing Cover Oil Seal MG 7
B TR2/3/3A Timing chain cover goop location Triumph 4
KVH General Tech Timing Cover Seal Triumph 3
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S TR2/3/3A timing chain cover and woodruff key Triumph 4
DanLewis Looking for a good timing chain cover Spridgets 1
D timing cover Spridgets 11
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
Dudly Sump and timing cover gaskets Triumph 1
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
TulsaFred Leaking timing cover Spridgets 15
J TR6 tr6 timing cover removal Triumph 3
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
L BN1 front timing cover seal Austin Healey 2
bugedd Tips on timing cover install Spridgets 4
bugedd Timing Cover Needed Spridgets 0
K TR2/3/3A The goop on the TR3 timing cover Again? Triumph 3
6 timing chain cover Triumph 4
R Timing cover oil seal MG 3
bugedd Timing Cover service Spridgets 1
bugedd Anyone have a timing chain cover? Spridgets 10
PatGalvin Timing Cover Seal Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
PeterK TR timing cover seal Triumph 3
PeterK TR4/4A TR3-4A timing cover tensioner Triumph 9
Bruce_B Where does hose from timing cover go? Spridgets 6
KVH Timing Cover Gasket Replacement Triumph 4
glemon TR5/TR250 Front Timing Chain Cover TR250/6 Triumph 6
KVH Timing Cover Seal Triumph 6
E TR6 TR6 Timing Cover Fasteners Triumph 7
ronzet Quick Query re: TIming Chain Cover MG 3
E TR6 TR6 Timing Cover Seal Triumph 7
E TR6 TR6 Timing cover removal Triumph 10
R interal thread stripped on timing chain cover Spridgets 2
TR4 Timing Chain Cover is stuck? Triumph 7
T Timing cover removal Triumph 15
S Stripped bolt on timing cover Spridgets 17
S Timing cover gasket sealer Spridgets 6
S Removing timing cover Spridgets 9
