timing chain cover
69tr
While I have the water pump off I thought I might as well check the timing chain.
Will I need to remove the cross brace and steering rack to clear the pulley and damper?
I plan to install an electric fan also.
KVH
The TR6 must be different from the TR4 in that regard, because I can't remove the front pulley and fax extension without loosening the steering U-Clamps and sliding the steering forward so that the steering rack doesn't interfere with the fax extension.
I once put a puller on the fan extension and noticed that I was pinching it right into the steering rack. Hardly any clearance there.
swift6
The frames aren't that different, but the engines are from different families and the locating is a little different.
69tr
I did have to take the U-bolts loose on the steering rack and move it forward a little bit. If I had looked in the Bently manual I would have known that.
Then I would not have had the pleasure of communicating with such fine folks.
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
B TR2/3/3A Timing chain cover goop location Triumph 4
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S TR2/3/3A timing chain cover and woodruff key Triumph 4
DanLewis Looking for a good timing chain cover Spridgets 1
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
glemon TR5/TR250 Front Timing Chain Cover TR250/6 Triumph 6
ronzet Quick Query re: TIming Chain Cover MG 3
R interal thread stripped on timing chain cover Spridgets 2
TR4 Timing Chain Cover is stuck? Triumph 7
Tinkerman Success w/ timing chain cover seal [aka sear0 Triumph 3
Tinkerman TR2/3/3A 60 TR-3A Timing chain cover. Triumph 8
L lowest bolts on timing chain cover MG 3
J oil leak at timing chain cover 1500 Spridgets 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
G TR4/4A timing chain and sprockets Triumph 9
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
