What's the right/best way to get the tensioner inside the cover without messing up the gasket? and then getting the cover on? I find that putting the cover on seems to be a 2 person job with one holding (fighting) the tensioner and another fighting to get the cover on straight without causing the other person to lose control of the tensioner. Has anyone done a YouTube demo on how to put the cover on? Thanks!
Regards,
Bob
I don't know about the best way or right way; but I did re do my cover 3 times on three consecutive days, and I got pretty good at it.
First I used hylomar blue on the engine face and applied the gasket there first. This seemed to be easier to me because you have to use the cover as a lever to control the tensioner .
second: i laid a small bead of hylomar on the gasket exposed side and a smear on the rim of the cover ( don't forget the fiber washer on the center pedestal that Randall mentioned)
third: use the inside lip of the cover to control the tensioner & aim for the stud first, once you have a toe hold on the stud , gently (& while holding your jaw just right ) swing the base in position.
the trick is not to try to force it & don't have the top bolt hole fully engaged on the stud until you have the pins & center pedestal lined up.
if you find reason to redo it, like I did, you will find acetone breaks down the hylomar very quickly & makes an excellent surface cleaner.
also a second fiber washer on the pedestal, outside of the cover, seemed like a good idea.
