Wheel Stud Size?
George Zeck
Hi All:
Just broke a wheel stud off. Any idea what size is standard? I'd hopeful to go to AutoZone and grab one. Just want to make sure I'm getting the right one.
Tx-
George Z
Autozone probably won't have it. It is 3/8-24. I do not know the length or the knurl size.
Nelson
For a local source you might give Winner's Circle a call on Monday. I've picked up a number of parts there. They are at Kamm's Corners on Rocky River Drive.
Jim_Gruber
OEM are 3/8 x 1" in front and 1.5" in the rear. You'll need to take the hubs apart and take it with you so it can be pressed in.
Joe Schlosser
George
Considering that all the studs are probably over 40years old and have been tightened multiple times over the years it would be a good idea to replace all of them or at least the other 3 on the same hub
The amount of work to replace all 4 is just a little bit more than doing one. Pulling the hub, front or rear is the big job. removing and installing the new studs is not a big deal.
Jim_Gruber
Agreed as I just got done doing that. If there are plans to upgrade your Rims to an 8 Spoke Minilite Style, you will need to go to a longer Wheel Stud. However there is a Catch 22. If you need to go to a longer stud length, a Stock rim i.e. a Spare Tire will not be able to be tightened down as you run out of threads. Keep that in mind. I just realized I'm going to need to order another rim for the spare.
Joe Schlosser
Jim
You can just take a 3/8 -24 die and cut the threads back to be even with the hub
Or, just zip tie a wheel spacer to your spare wheel.
I Also have 4 orig lug nuts zip tied to my spare wheel as I have the Mag style full insert type of wheels.
Jim_Gruber
Joe, I don't think a die will do this. But I'l lgive it a try.
Joe makes a good point. I think the lug nuts for the original wheels were a round shoulder and the ones for the alloys are likely a straight taper. Probably not a big issue, but something to keep in mind.
M_Pied_Lourd TR2/3/3A Wheel Stud Question Triumph 4
N Wheel stud dimensions? Spridgets 10
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
S Wheel stud length???? Triumph 10
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
boeingpilot TR4/4A TR4A Wheel Stud Removal Triumph 12
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
Monark192 Broken Wheel Stud Removal Spridgets 4
Jim_Gruber Broken Front Wheel Stud Spridgets 16
mrv8q TR6 TR6 Wheel stud Triumph 2
SCguy rear wheel stud Triumph 11
I wheel stud replacement help Triumph 4
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
kodpkd Leather Steering Wheel Cover Austin Healey 3
KVH General Tech Wheel Dollies Triumph 5
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
P 100/6 Front Wheel Alignment Austin Healey 10
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
prb51 BN6 Wheel/Tire Combo Austin Healey 26
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
LAW75 Derrington Steering Wheel Austin Healey 19
C Spitfire rear wheel bearing Triumph 2
