TR2/3/3A The Reason for my Rebuild
RedTR3
Well, here's a photo of what happened to the TR3 on July 4...Luckily no damage was done to the engine!
mallard
Nothing a little JB-Weld can't take care of. Your lucky you didn't destroy the block.
Never seen that happen to a TR crank before. Had a Midget years ago, crank broke right in the middle main, engine still ran but made funny noise when you pushed in on the clutch. Dad and I had a time figuring that one out.
Marv
tinman58
I think that a little super could fix that!!
I was just at a friends who has a Morgan. The flywheel spins but the motor does not. The problem could be very much the same.
martx-5
That's NOT an isolated incident. The crank has been know to break in just that spot. Often times at a rather slow speed.
gbtr6 TR6 Reason for my rebuild Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
Rut Any reason not to mount this here? Spridgets 21
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S Off Topic Reason 193 why I love little british cars [especially TRs] Triumph 8
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 20
J Any reason to not change the color of a Sprite? Spridgets 10
Jer Another reason why it's great to own a Spridget Spridgets 9
tahoe healey real reason for no tunes Austin Healey 21
germanmichel Reason of SU fuel pump strike Austin Healey 9
tony barnhill I know there's a reason, but... Spridgets 14
Trevor Jessie What is the reason for this Spridgets 9
JPSmit There's a reason I haven't - but a question Spridgets 12
jlaird For some reason Spridgets 5
jlaird Another reason Spridgets 8
J The reason stated the Esprit will disappear after 2003 is....[look inside to find out Lotus 2
Carlbanan56 MGB MGB rear break rebuild MG 6
6 Master Cylinder Rebuild Spridgets 6
wangdango Carb Rebuild Necessity Austin Healey 3
drooartz MGB Front suspension rebuild is next MG 57
KVH General Tech Rebuild Report Triumph 6
KVH General Tech Initial Start Up After Rebuild Triumph 23
KVH General Tech More Engine Rebuild Questions Triumph 15
G MGB '71 MGB Front End Rebuild MG 2
drooartz MGB A nice milestone since the rebuild MG 3
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
I Bugeye valve rebuild suggestions Spridgets 8
D MGB 25D dizzy rebuild MG 29
R Rib Case rebuild... Spridgets 5
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
woolfman C39 vs C40 Dynamo rebuild/parts Spridgets 0
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
B TR2/3/3A TR3a steering box rebuild Triumph 19
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
RJS General TR TR4A Seat Rebuild Triumph 12
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
J Transmission and Overdrive Rebuild Austin Healey 6
J TR6 TR6 Differential Rebuild question Triumph 6
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
