TR2/3/3A Further to brake caliper rebuild....
karls59tr
Bronze
I just saw on the "red rubber grease" site that they pack the caliper piston dust boots with grease? I did not know this was recommended but it does make sense to keep moisture out. My concern is that with that amount of grease in there it might cause the dust boot to slip out of its slot in the piston?
Should have looked at this site before I pressed the pistons in as it shows the grease just slathered on the bore and piston. I just put a thin coat on the bore and piston?? Any thoughts?
DougME
I don't fill the boot with silicone grease but I .......
Sorry about the stuff below, ignore.
charleyf
I have done about five sets now and only used a dab of brake fluid on the seal and piston before inserting the piston into the caliper. Any additional grease is just going to attract dirt that will build up on it.
Charley
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K For Sale Further Pics of TR3 SU's Triumph Classifieds 0
H Mk.II ratty white one near Ontario,CA--I could investigate further Jaguar 1
K TR4/4A Further to Veneering the Dash.... Triumph 4
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K Further to carb cleaning ...careful with SU domes. Triumph 7
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
K TR2/3/3A Further toTR3 "flattening out at 80"..... Triumph 2
K Further to wishbone clearance at steering box... Triumph 1
Number_6 TR2/3/3A Further progress on TR3! Triumph 6
drooartz Going one step further, to modify or switch? Spridgets 50
DerekJ 100-Six Web Site - Further Up-dates Austin Healey 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
