General Tech Timing Cover Gasket Flub Up
KVH
I'm so frustrated. It seems I can't fix anything right now. I just put my timing cover on with a new gasket. I used a blue gasket maker from a 6 year old unopened tube. It seemed a bit like Hylomar, and I wasn't worried about anything. The instructions recommended it for timing covers. After I got the cover reinstalled and torqued I could see large pieces of my gasket torn and protruding from the sides of the timing cover. Due to the angle I was working, I didn't notice anything awry while I was reinstalling the cover. But, seriously, it's as if something shredded my gasket or as if the bolts bound up in the fibers at each bolt hole and pulled and tore at it. It was torn and distorted in at least four places. I've never seen such a thing. Anyone else?
dklawson
I have experienced that when I didn't follow the torque specs for the timing cover and sump bolts. I'm not saying you did that but I know it is what caused the problem for me.
CJD
I've had that too, often with both cork and paper type gaskets used on timing covers and oil pans. Hylomar is very "slick". If you put it down and immediately torque the gaskets, the lubricating quality of the hylomar can shred the paper gasket. I've experienced the same thing with silicone sealants too. I learned that when I use those type gasket sealers I use very little on the gasket, and I only install the bolts snugly at first. I wait an hour or so and then finally torque the bolts to spec. Remember that most gaskets don't need any sealer added at all, so only use the very thinnest line as "insurance", if the metal is gouged or pitted. Large amounts add to the tendancy to shred the paper.
The thicker, viscous, gasket maker has less of a tendency to shred.
sp53
The last timing cover gasket I got in a kit was so thin it was worthless. I bought some heavy gasket material and used it for a pattern. Heck that might have actually moved the timing cover seal out to a new spot on the hub by pushing every out some. Plus the holes on the cover get pooched out and sharp and need to be pounded back.
steve
LAW75 Timing Chain Cover Gasket Austin Healey 12
KVH Timing Cover Gasket Replacement Triumph 4
S Timing cover gasket sealer Spridgets 6
hondo402000 TR6 TR6 timing cover seal and gasket fix Triumph 7
J Next project:: timing cover gasket and crank seal MG 2
M 1275 Timing Cover Vent Spridgets 2
A Timing cover access Spridgets 6
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
C Wanted Timing gear cover 1275 Spridgets Classified 2
JFS General MG Timing Cover Oil Seal MG 7
B TR2/3/3A Timing chain cover goop location Triumph 4
KVH General Tech Timing Cover Seal Triumph 3
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S TR2/3/3A timing chain cover and woodruff key Triumph 4
DanLewis Looking for a good timing chain cover Spridgets 1
D timing cover Spridgets 11
vette Timing Cover crankshaft pulley seal Austin Healey 6
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
Dudly Sump and timing cover gaskets Triumph 1
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
TulsaFred Leaking timing cover Spridgets 15
J TR6 tr6 timing cover removal Triumph 3
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
L BN1 front timing cover seal Austin Healey 2
bugedd Tips on timing cover install Spridgets 4
bugedd Timing Cover Needed Spridgets 0
K TR2/3/3A The goop on the TR3 timing cover Again? Triumph 3
6 timing chain cover Triumph 4
R Timing cover oil seal MG 3
bugedd Timing Cover service Spridgets 1
bugedd Anyone have a timing chain cover? Spridgets 10
PatGalvin Timing Cover Seal Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
PeterK TR timing cover seal Triumph 3
PeterK TR4/4A TR3-4A timing cover tensioner Triumph 9
Bruce_B Where does hose from timing cover go? Spridgets 6
glemon TR5/TR250 Front Timing Chain Cover TR250/6 Triumph 6
KVH Timing Cover Seal Triumph 6
E TR6 TR6 Timing Cover Fasteners Triumph 7
ronzet Quick Query re: TIming Chain Cover MG 3
E TR6 TR6 Timing Cover Seal Triumph 7
E TR6 TR6 Timing cover removal Triumph 10
R interal thread stripped on timing chain cover Spridgets 2
TR4 Timing Chain Cover is stuck? Triumph 7
T Timing cover removal Triumph 15
S Stripped bolt on timing cover Spridgets 17
