OK, I have to ask. Which side is open? I could make an argument for each side.
One side has more of a steel face than the other; and that side is opposite of the side with that tight spring wire winding around the outside circumference of the fitted rubber seal.
In fact, if I'm looking through the seal from the side with more steel, I'm looking at the inside surface of the beveled part of the rubber seal at the far end, and from that vantage point I can't see the spring wire since its on the far side behind the rubber seal.
If that makes sense.
Maybe I need to send a picture.
