bugedd
I am putting my timing cover back together and want to make sure it won't leak. Normally I would just slip the crank seal in, put a little permatex high temp on the gasket and call it good. But with the high quality and accurate stamping they did with this cover (sarcasm?), I am worried about it sealing. So, should I put a bit of permatex on the crank seal between the seal and the cover? And any other advice?
