Wheel cylinder fitting kit - any tips?
tr4boy
I'm trying to re-fit the wheel cylinders on my 64 tr-4. I'm using the moss wheel cylinder fitting kit and having a hard time getting third clip in place without it bending. Anybody have a trick to getting these buggers in place?
thanks,
Greg
Mickey Richaud
Not much help on this end, Greg, but just wanted to say you have to have the award for longest membership without posting! :devilgrin:
You might try ~squeezing~ the cylinder in place with vise grips or a c-clamp to expose the recessed area for the clip.
Welcome!
:cheers:
Mickey
TR4nut
Welcome- always glad to have another TR4 owner in here.
This came up recently and I didn't have a good link. Still don't have a perfect one, but take a look at this discussion:
Wheel Cylinder install
In the picture you will see three of the locking plate parts labeled A, B, C. The trick is to install A and B first, then drive in C in between the two installed parts. So that little clip labeled B is not the last piece to go in. No bending, once you get the hang of it you'll find it easy I think.
Randy
S TR2/3/3A rear wheel cylinder Triumph 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
A TR2/3/3A Wheel cylinder issue? Triumph 0
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
J TR4/4A TR4A rear wheel cylinder source Triumph 3
R Freeing wheel cylinder locking plate Austin Healey 7
RickPA BJ8 rear wheel cylinder install Austin Healey 1
trotti Pulling off the rear wheel cylinder Austin Healey 11
D TR4/4A Wheel Cylinder Backing Springs Triumph 11
S Wheel cylinder installation kit Austin Healey 2
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
C TR4/4A TR4A wheel cylinder install Triumph 4
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
RickB Wheel cylinder failure Spridgets 17
T 76 midget rear wheel cylinder Spridgets 5
B rear wheel cylinder C clip install?? ugh Spridgets 24
G What's up with this wheel cylinder hole boot? Triumph 10
5 one inch rear wheel cylinder Austin Healey 1
R HELP! Wheel brake cylinder clip MG 9
D Rear wheel cylinder replacement question BT7 Austin Healey 6
Stinger TR4/4A TR4A Rear Brake Wheel Cylinder Dust Shields Triumph 5
R Austin healey BJ& rear wheel cylinder problem. Austin Healey 4
athenssprite removing wheel cylinder Spridgets 2
R BJ-7 rear wheel cylinder removal Austin Healey 4
19_again Leaky wheel cylinder MG 8
Twosheds Jensen-Healey Wheel Cylinder Other British Cars 2
T Wheel cylinder identifier Triumph 11
MGretired Rear wheel cylinder retaining clip MG 9
Banjo wheel cylinder cross refrence??? Jaguar 3
J Rear Wheel Cylinder Removal Spridgets 3
6 Wheel Cylinder Fluid leak on BJ8 Austin Healey 7
W clogged wheel cylinder Austin Healey 8
S Front Wheel Cylinder Woe's Austin Healey 15
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
