TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine
RedTR3
Need Tips for Breaking in a Rebuilt TR3 Engine
Hopefully in a couple weeks I'll be back on the road...I am sure that the mechanic/machinist will have instructions for breaking in, but I would very much appreciate any knowledge from you guys.
What I will have is new pistons/rings/liners, lifters, cam reground, cam bearings, crank turned to 10/10, line bored block, new head studs, etc.. Head was rebuilt earlier this year.
Thanks for any tips/advice!
TR3driver
Great Pumpkin - R.I.P
Kas Kastner, Greg Solow, and several other well-known TR engine builders recommend immediately running the engine for 15-20 minutes at a fast idle (1500-2000 rpm) with NO blipping of the throttle. According to Kas, this allows the critical areas of the cam lobes to work harden and mate to the lifters. Obviously keep a close eye on the engine, checking for leaks, overheating, bad noises, etc. If you have one, directing a fan into the radiator may be a good idea as well.
TR4nut
This is one area where I err on the cautious side and use ZDDP or products like GM EOS and a good break in oil from Joe Gibbs or Brad Penn for the getting the engine going. Also, I'm more comfortable with using a shaft to spin up the oil pump to at least get pressure up before the first start up.
Once things are off and running, I would also follow the factory recommendation and retorque the head after 500 miles. Very surprising how much it can loosen up.
sammyb
I'm with Randy, during the initial running, most engine builders suggest using a "break in oil" with high ZDDP levels. Generally, use 100-150 miles of running on the first oil, then change it (and either use more break-in oil, or standard oil with a high ZDDP additive) and go through 500 miles, then change again and just use your preferred oil.
After that initial high idle running to break in the cam, once you're actually driving the car, the standard rules should apply: vary the speed/rpms and avoid wide-open-throttle.
Since TRs are low-stress engines (provided they are below redline ;) ) you shouldn't have much problem.
CJD
Break in the cam and then drive it like you plan to use it. The only hard rule is not to cruise at a steady RPM, like locking 60mph for hours on the freeway, for at least the first 500 miles. Vary the rpm regularly to ensure everything in the motor stays lubricated.
Bruce100
prime the oil system before starting, verify they got the cam bearing in right by watching for oil to spurt through the rocker arms.
Monkeywrench
A friend of mine with a FAST TR4 race car. Has been building race engines for 50 years.
20 minutes at 3000-3500rpm. Let sit overnight. Retorque the head cold. 20 minutes again doing the same. Change oil. Go racing.
How I just did my bike (roller cam):
15 minutes fast idle (just trying to get everything to do a heat cycle). Let sit overnight. Retorque head cold. 1/4 throttle ride up to 60, engine brake down to about 20 (downshifting so it doesn't lug). Do that a few times. Repeat at half throttle and lastly at full throttle. Change oil and done.
You want a good oil with higher amounts of ZDDP regardless. This has been beaten into submission countless times. Try to use a non fully synthetic oil for breaking in. Brad Penn, Joe Gibbs (now called Driven), Amsoil all have specially formulated break-in oils. Might have to mail order it, but just hit the easy button and do that.
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
J Tips for quarter elliiptic spring install Spridgets 3
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
PC DIY tips from Bo his self Other Cars 0
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
drooartz Installing front hubs, tips? Spridgets 15
bugedd Bench bleed tips Spridgets 14
S TR4/4A Electrical wiring tips Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
F Buying a 100.... tips Austin Healey 18
drooartz MGB Changing clutch hose - tips? MG 13
T Tips for Searching FORUM Navigation Questions 2
T TR4/4A Any tips on re-torquing TR4a head now that 500 are on the rebuild Triumph 7
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M tips please on removing starter motor on 100-6 Austin Healey 6
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
bugedd Su adjustment tips Spridgets 7
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
PatGalvin TR2/3/3A Carpet Install Tips Triumph 12
Bob_Spidell Tips Austin Healey 6
Tinkerman TR2/3/3A Front Fender Installation Tips Triumph 3
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
W Looking for tips: BJ8 roll up windows Austin Healey 10
I TR6 Any tips on removing flasher switch Triumph 3
M Radiator Hose tips? Spridgets 0
T TR4/4A Any tips on running the overdrive switch wiring down the steering column? Triumph 11
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
bugedd About to rebuild front end...any tips? Spridgets 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
apbos Two Restoration Tips Spridgets 11
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
5 TR2/3/3A TR3 engine building tips needed Triumph 5
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
Lbp Install l-t-d fasteners on new tonneau - Tips? Triumph 8
T Wheel cylinder fitting kit - any tips? Triumph 4
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
J 67 IRS Exhaust Tips Triumph 2
RickB Painting tips anyone? Spridgets 13
RJS Water Pump Replacement Tips Triumph 8
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
aeronca65t Kasnter tips Triumph 8
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
drooartz Any tips for replacing brake hoses MG 16
