TR4/4A Making an OD pressure gauge - any tips?
tdskip
Hi guys - anyone ever make an OD pressure testing gauge setup? My A-type OD is not engaging despite being full of oil and manually articulating the engagement mechanism.
I want to make sure I have pressure (or not) before pulling the gearbox. No one down here seems to have one but I'm thinking it can't be that hard to make one.
McMaster Carrr should have all the bits, or so I am thinking.
So, anyone been there and done that?
titanic
I made one similar to the gauge shown on the Buckeye site. I presume you are familiar with the excellent articles on the A type OD, including a trouble shooting chart.
Anyway, the gauge is 600 psi glycerin filled. Next, is a 1/4' npt female connector followed by a 3'' length of 1/4" pipe, and finally an adapter-1/4" npt female to 1/2"-20 male. The adapter is an easy lathe project, the other fittings are available from a hardware store or industrial supplier. Or for about $50 you can buy one from Jay Holecamp, who advertises on the VTR site.
Berry
https://www.tr-register.co.uk/forums/uploads/post-10575-0-80659800-1350943334.jpg
I bought one from Jay a couple of months ago. I'd say get one from him to save time ( and money). Plus you know it will be correct.
Marv
TR3driver
Great Pumpkin - R.I.P
Like Berry, I made my own. Gauge from MMC, pipe from HD, adapter I turned myself. It was fun; but the end is more than just 1/2-20 threads. The inside has to be bored to the right length, to accept the spring for the operating ball; and the outside has to have the flat sealing surface (where the copper washer sits). Another alternative, if you have a damaged plug, is to braze or weld a tube to the plug.
Lots simpler to buy one from Jay.
Absolute requirement for OD troubleshooting, IMO.
PS, maybe it was just the gauge I got, but when I left it laying flat in the roll away, all the glycerin gradually leaked out. Apparently they are serious about mounting with the threaded end down.
titanic
I should have added that the 1/2" end of the adapter is basically a duplicate of the op valve plug, but only involves drilling the id and machining a square shoulder on the od for the sealing washer.
Your problem with the OD may be as simple as the adjustment of the op valve. Sometimes using the 3/16" rod procedure doesn't provide enough valve lift and it is necessary to move the lever slightly beyond the point where the hole in the lever and od case are aligned.
Berry
T
tdskip
Thanks Berry, good thought on the lever. When I was staring at the diagrams and the Buckeye site last night it occurred to me that could be it. Doubt I'll get that lucky but worth a shot!
A Why is my car making this noise? Other Cars 5
mctriumph 61 Morgan making progress Other British Cars 3
KVH General Tech Making the Triumph Engine Dolly Triumph 4
A Making an A-series engine stand adaptor fitting Spridgets 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
H Making a '73 Midget into a '63 Midget Spridgets 2
matmire gonna try making some wind wings. Spridgets 13
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
D 69 E-Type sputters when making left hand turn Jaguar 6
Got_All_4 TR2/3/3A I'm making my own door panels and .... Triumph 11
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
tomshobby General TR making it easy to lube door hinges Triumph 0
drooartz Making [tiny] progress Spridgets 14
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
7 Post-War Other Back to making progress Triumph 5
glemon Restoration Vs. Making it Go Restoration & Tools 14
drooartz MGB Making some progress with the doors MG 5
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
G How do I know I am making the right decision? Jaguar 7
AN5Sprite Making room Spridgets 0
J Making Room Triumph 2
RickB Who can guess what I'm making? Spridgets 37
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
Darrell_Walker Making a wire wheel tubeless? Triumph 45
Aggudabbu Making some progress Spridgets 5
glemon Making Strombergs Richer Triumph 22
F Are the russians making a hybryde .... Other Cars 0
hondo402000 Making your Avatar Pic Triumph 14
Sarastro Tool for making bubble flares on brake lines Restoration & Tools 14
M_Pied_Lourd Making Progress Triumph 314
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
G Making a faux roll bar into a real roll bar Triumph 2
RickB OT: talk about making a Spridget Hybrid? Spridgets 0
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
drooartz Making more calls today Spridgets 6
T Making a steering wheel Austin Healey 41
DNK My 6 is Making Me Frustrated Triumph 10
Stewart Making progress finaly MG 7
T Making straight cuts & smooth edges for patches Triumph 5
George Zeck Making good progress ..... Spridgets 11
7 Making progress finally Triumph 1
G Still making the covers after 30+ years Triumph 0
healeyboz Making the switch to Spridgets 19
drooartz Making a dashboard Spridgets 28
S I'm making it WORSE! HELP! Triumph 15
G Making my winter maintenance checklist Triumph 11
KLUTZ MGB-GT Making progress on the GT MG 14
