Making a faux roll bar into a real roll bar
G
As many of us have, I am using a faux roll bar, for show only, sorta. Well, I have the rear glass welded into the thing as well as the third brake light but any way to fabricate a piece that can affix to the frame below, perhaps bolted into the frame, and seat below the faux roll bar from the bottom. Then with some serious-strong bolts, bolt through the body and into the roll bar brace. In essence, creating a stronger roll bar and one that might even pass as the real thing.
Brosky
That "faux" roll bar that you talk about saved two of my fellow CCBCC members when they were slammed into from behind, pushed up and over an embankment and had a subsequent roll over. It may not be SCCA, but it's better than nothing!
And it makes a great place to mount an upper level lamp and comes in handy for pushing your car in and out of a work area.
But it won't make 1000's of Julian fries as far as I know.
gjh2007
I guess my only concern is that it cannot be folded over and act like a guilletine in a rollover.
I have one hanging on my garage wall I am not sure what I am going to do with.
It's been a flourecent lite holder over my work bench since 1985! Course I didn't even have a TR from '80-'05!
A Why is my car making this noise? Other Cars 5
mctriumph 61 Morgan making progress Other British Cars 3
KVH General Tech Making the Triumph Engine Dolly Triumph 4
A Making an A-series engine stand adaptor fitting Spridgets 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
H Making a '73 Midget into a '63 Midget Spridgets 2
matmire gonna try making some wind wings. Spridgets 13
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
D 69 E-Type sputters when making left hand turn Jaguar 6
Got_All_4 TR2/3/3A I'm making my own door panels and .... Triumph 11
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
tomshobby General TR making it easy to lube door hinges Triumph 0
drooartz Making [tiny] progress Spridgets 14
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
7 Post-War Other Back to making progress Triumph 5
glemon Restoration Vs. Making it Go Restoration & Tools 14
drooartz MGB Making some progress with the doors MG 5
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
G How do I know I am making the right decision? Jaguar 7
AN5Sprite Making room Spridgets 0
J Making Room Triumph 2
RickB Who can guess what I'm making? Spridgets 37
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
Darrell_Walker Making a wire wheel tubeless? Triumph 45
Aggudabbu Making some progress Spridgets 5
glemon Making Strombergs Richer Triumph 22
F Are the russians making a hybryde .... Other Cars 0
hondo402000 Making your Avatar Pic Triumph 14
Sarastro Tool for making bubble flares on brake lines Restoration & Tools 14
M_Pied_Lourd Making Progress Triumph 314
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
RickB OT: talk about making a Spridget Hybrid? Spridgets 0
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
drooartz Making more calls today Spridgets 6
T Making a steering wheel Austin Healey 41
DNK My 6 is Making Me Frustrated Triumph 10
Stewart Making progress finaly MG 7
T Making straight cuts & smooth edges for patches Triumph 5
George Zeck Making good progress ..... Spridgets 11
7 Making progress finally Triumph 1
G Still making the covers after 30+ years Triumph 0
healeyboz Making the switch to Spridgets 19
drooartz Making a dashboard Spridgets 28
S I'm making it WORSE! HELP! Triumph 15
G Making my winter maintenance checklist Triumph 11
KLUTZ MGB-GT Making progress on the GT MG 14
