Well it turns out the reason my car was running rough and the reason it died are not related. The dieing and then not starting was a bad wire going to the coil. I fixed that and the car is running rough (just like before). Here is where the story gets worse and I am not sure what to do.
I checked the points by measuring (.015) and by dwell meter (upper 40's), so that sounds right to me. I do not have a continuity light so I have not static timed. However, I have put a timing light on each cable to see if I was at least getting regular firing. It turns out the firing is very irratic on all cylinders (it very bad on #3). If I put the timing light over the coil cable, it is pretty regular, but it does occasionally have some irregularity.
It is clear from what I am seeing with the timing light and from what I am hearing and feeling with the engine, that there is an ignition problem. The car has a very irregular exhaust note and the engine rocks a lot in the engine bay due to the roughness.
To add some more pain to this, I previously ( a week or so ago) thought my rough running and lack of starting was due to fuel issues and I had messed with the carbs (I know I am not supposed to do that before I elliminate the ignition issues, but I messed up and did it anyway - call it a learning experience /bcforum/images/%%GRAEMLIN_URL%%/crazy.gif). I am getting an occasional backfire out of the rear carb (when I really hammer the accelerator) and is leaking a bit of fuel. The exhasut does have some black smoke, so I think it is rich, but if I raise the carb piston slightly, engine speed decreases (which is the opposite of running rich according to my tune-up guide).
Anyway, it is worse than when I started and I am even a little hesitant to drive it to the mechanic, which is 15 miles away or so.
Some specific questions:
Since I am getting irregular spark at all of the plugs, is there something that would be most suspect? Condensor? Coil? Wiring inside the distributor? The Cap itself?
Any systematic way to eliminate the good and bad parts? I am thinking if I can just get a regular spark, I can fix the fuel adjustments. I think I am not able to undo what I have done to the carbs at this time because of the spark issue. I assume that if the car is not firing when it is suppossed to, the gas does not ignite and could also create black smoke. /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
At this point I feel like I am just randomly guessing (you probably gathered that from the rambling nature of this message) which will probably lead to more problems, rather than fewer. My wife is also about to lose it as I have dedicated most of the daylight hours this weekend to making the car run worse!
So I have agreed to stop for now, park the car, write this e-mail and enjoy a 65 degree Super Bowl Sunday!
If I can manage to swap out a cheap part and get the firing under control, I think I can fix it. Plan B would be to at least get the car running well enough to feel comfortable driving it to my mechanic.
As always, thanks in advance for any help you might provide.
