My 6 is Making Me Frustrated
DNK
Every time I make 1 step forward 2 steps back is next (wasn't there another post like this).The new starter I bought on eBay (fleabay to some) to fit around the headers doesn't fit right and the electrical hook ups don't fit to my satisfaction as the are against the pan and in a blind position. I have reclocked it to a more satisfactory position but then the headers interfere with it. /bcforum/images/%%GRAEMLIN_URL%%/mad.gif Am getting pretty #@$**! I order a fuel filter for the pre filter for the Carter fuel pump,won't fit in the location I want. I have to send that back and am back to square 1 on that. The 5 way connector I ordered from British Wiring never got here as they used an old zip code instead of the new 1 I provided. At least that is on it's way again. Took me 3 times to make the alt. adjuster before I got it right but now I think the GM Alt. is not quite on the same plane as the front pulley.
Some times I feel I will never get this thing finished!!! /bcforum/images/%%GRAEMLIN_URL%%/cryin.gif
DougF
Gotta love it! Would you expect more?
Unfortunately, we've all been there. As one of our past Presidents used to say, "I feel your pain".
Brosky
Looks like Pedro migrated to the north....and west......
Moseso
I've been wondering about the static nature of your "Then & Now" sig pix. Now I understand.
hondo402000
when I get frustrated, just put down the wrench and take a break and cool off, think about it and then go back to work
kodanja
The reason I bang my head against the wall is because it feels so good when I stop!
/bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif
G
Thank you for keeping the prices low on OEM stuff. I enjoy changing parts, but not fabricating new ones.
tr6_easyrider
DNK
Here are some pics of my conversion using the chrome Chevy
bracket. The piece I cut from the bracket was used for a support in the back, which helps with keeping it in the same plane as the water pump pulley. I had to cut more from the alt. than some articles suggest, not sure what that amount was, but it was beyond the casting seam.
https://s165.photobucket.com/albums/u44/Tr6_easyrider/?action=view&current=IM000423.jpg
https://s165.photobucket.com/albums/u44/Tr6_easyrider/?action=view&current=IM000424.jpg
https://s165.photobucket.com/albums/u44/Tr6_easyrider/?action=view&current=IM000425.jpg
https://s165.photobucket.com/albums/u44/Tr6_easyrider/?action=view&current=IM000426.jpg
https://s165.photobucket.com/albums/u44/Tr6_easyrider/?action=view&current=IM000427.jpg
https://s165.photobucket.com/albums/u44/Tr6_easyrider/?action=view&current=IM000428.jpg
https://s165.photobucket.com/albums/u44/Tr6_easyrider/?action=view&current=IM000429.jpg
The Flennor belt is the stock size for Tr6, purchased from TRF a "few" years ago.
Joe
DNK
DNK
Don't follow you.
If that was a jab at the fact my rant was on unstock stuff,I resemble that.You should see the car. The body and block are stock.
G
DNK said:
Don't follow you.
No jab at all. I mean it. Everyone is using GM and Bosch so Lucas alternators are still pretty cheap brand new. I'm not one to cut brackets and such so if my alternator goes, it's a cheap easy fix.
Your car is coming along nice. It looks great.
A Why is my car making this noise? Other Cars 5
mctriumph 61 Morgan making progress Other British Cars 3
KVH General Tech Making the Triumph Engine Dolly Triumph 4
A Making an A-series engine stand adaptor fitting Spridgets 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
H Making a '73 Midget into a '63 Midget Spridgets 2
matmire gonna try making some wind wings. Spridgets 13
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
D 69 E-Type sputters when making left hand turn Jaguar 6
Got_All_4 TR2/3/3A I'm making my own door panels and .... Triumph 11
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
tomshobby General TR making it easy to lube door hinges Triumph 0
drooartz Making [tiny] progress Spridgets 14
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
7 Post-War Other Back to making progress Triumph 5
glemon Restoration Vs. Making it Go Restoration & Tools 14
drooartz MGB Making some progress with the doors MG 5
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
G How do I know I am making the right decision? Jaguar 7
AN5Sprite Making room Spridgets 0
J Making Room Triumph 2
RickB Who can guess what I'm making? Spridgets 37
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
Darrell_Walker Making a wire wheel tubeless? Triumph 45
Aggudabbu Making some progress Spridgets 5
glemon Making Strombergs Richer Triumph 22
F Are the russians making a hybryde .... Other Cars 0
hondo402000 Making your Avatar Pic Triumph 14
Sarastro Tool for making bubble flares on brake lines Restoration & Tools 14
M_Pied_Lourd Making Progress Triumph 314
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
G Making a faux roll bar into a real roll bar Triumph 2
RickB OT: talk about making a Spridget Hybrid? Spridgets 0
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
drooartz Making more calls today Spridgets 6
T Making a steering wheel Austin Healey 41
Stewart Making progress finaly MG 7
T Making straight cuts & smooth edges for patches Triumph 5
George Zeck Making good progress ..... Spridgets 11
7 Making progress finally Triumph 1
G Still making the covers after 30+ years Triumph 0
healeyboz Making the switch to Spridgets 19
drooartz Making a dashboard Spridgets 28
S I'm making it WORSE! HELP! Triumph 15
G Making my winter maintenance checklist Triumph 11
KLUTZ MGB-GT Making progress on the GT MG 14
