Yes, it will fit. You can also incorporate other 1275 items onto the 948 if you like, harmonic balancer, duplex timing chain and gear set up. The 1275 had to come up with another source to breath the crankcase, because they no longer had lifter covers, so hence the can on the timing cover. The got away from the felt seal with the 1098, those cover the rubber seal goes in from the front, where with the 1275, the seal goes in form the inside of the cover, I always use the 1098 front timing cover on the 948s, I get the good seal, but no one can tell that I don't have the original timing cover on.
The deal with the seal, as most of you know, it fits around the OD of the snout on the harmonic balancer, or front pulley, that size never changed in the entire production of run of A series RWD engines, so it's all interchangeable.
David this might be a wonderful time to make top timing pointer for your engine.
