Brake Pedal Feel
RDKeysor
Bronze
Replaced my '60 BN7 master cylinder a couple of months ago with a standard 5/8" bore type as used on the Series 1 cars without servo. I also switched to NAPA Dot 4. Even though I bled the system thoroughly, I had maybe 2" of pedal travel before I got braking, the pedal firm at that point. The other day a front wheel cylinder failed, so I purchased rebuild kits and new pistons (the ones in the car had a chrome look and corrosion rings with some pitting about where the inner rubber seals contacts them). Since I had a lot of previous recommendations that I replace the rubber hoses with the stainless steel mesh type, I bought the set from Moss and installed them, front and back, along with the new pistons and rebuild kits. However, I still have the same long pedal travel before getting my hard pedal, and that distracts from any benefit I might have had from the new brake hoses. I'm considering buying the 7/8" bore master cylinder specified as being for cars with servos thinking that the larger diameter will move more fluid and eliminate the long pedal throw. I own a complete servo kit that I have been reluctant to install until I am satisfied with the function of the system without the added complexity. I might add that I recall the pedal travel as being shorter before I began this process, which was occasioned by the large amount of crud in the brake fluid. It comes out crystal clear now, and I have put a lot of it through the system. Thoughts?
bdcvg
I don't think the larger diameter equals less pedal travel. My BJ8 was converted from large servo master to smaller non-servo BJ7 master plus braided lines and there is much less pedal travel now.
vette
I'm not an expert in hydralics and such, but even in reading about hot rod build projects I believe that the smaller diameter master cylinder contributes to more pressure which is better than more volume. I might be wrong. I know I have always found it difficult to get a good bleed on my BJ7 brakes. I do believe that it is because of the smaller size of the bore of the Master Cylinder. As said earlier, it doesn't move much fluid so when trying to move the air out of the system it takes alot of time (when using the pump the pedal method). But once the system is bleed up, VERY WELL, I believe the smaller bore master cylinder contributes to a harder pedal.
Gearhead_Garage
Gearhead_Garage
I finally received my stainless lines from England (motorsport-tools.com). They are stainless coated with a dark transparent sleeve, sort of half-way between rubber and stainless. They look stock until you look closer.
They took forever to arrive but they sure are purty. I could have had the Moss or Goodridge lines installed by now but sometimes you just want to give your Healey a new toy.
I am renovating the shop so no car work until it is finished. I'll report back on a before/after.
attachment.php
RDKeysor
Bronze
Coincidental to my brake issue, I think I have confirmed to my own satisfaction Norman Nock's "Tech Talk" observation that Healey's don't respond well to pressure bleeders, in my case a Mighty Vac (sic). I had tried this on two occasions and kept getting air bubbles, but when I then used the two-man bleeding system, I quickly got clear fluid. I have a Motive (sic?) pressure bleeder, the type that holds brake fluid and pressurizes at the reservoir. This works well on my Porsche 968, but these things are specific to the brake fluid reservoir cap/threads. Don't have the Healey cap fitting. I will be curious about observations on vette*'s comment regarding cylinder diameter and hydraulic response. I know zilch about that but remember well that four 1" water line capacity doesn't compare to one 4" line. Just trying to further confuse the issue!
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
F Excessive Brake Pedal Travel Austin Healey 3
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Sopwith_Camel MGB pulsing brake pedal MG 10
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
bighealeysource Soft Brake Pedal Austin Healey 7
S Receding Brake Pedal Austin Healey 32
K Midget Brake Pedal Question Spridgets 2
D TR2/3/3A clutch/brake pedal question Triumph 4
steveg "Sticking" the brake pedal Austin Healey 3
Michael Oritt Brake pedal contact or mercury switch Austin Healey 19
H BN1 Brake Pedal Hitting The Downpipe Austin Healey 9
R Low Brake Pedal Austin Healey 9
Joe_Healey Brake Pedal Rod Painted or Natural Austin Healey 14
T TR2/3/3A soft brake pedal on TR 3 Triumph 5
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
H TR4/4A Soft Brake Pedal Triumph 3
PatGalvin TR2/3/3A Brake MC Bracket and pedal assembly install Triumph 24
angelfj1 TR5/TR250 Brake Pedal return spring Triumph 2
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
eschneider machine gun brake pedal Other Cars 3
T Soft brake pedal on BJ8 Austin Healey 3
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
W TR6 TR6 brake pedal drip Triumph 12
C brake pedal to the floor Austin Healey 6
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
CJD Brake/Clutch pedal adjustment Triumph 29
K Brake pedal doesn’t move mcylinder didn't fix Triumph 7
J Brake pedal cover removel? Triumph 5
J Brake/clutch pedal frozen Triumph 18
livinginthepast Disc brake conversion - soft pedal Spridgets 8
TR4 Brake Pedal Travel Adjustment Triumph 18
S BN1 clutch and brake pedal bracket Austin Healey 3
go_inbroke Brake pedal Triumph 12
N Brake pedal to the floor Austin Healey 13
Thor Brake light, do you have to remove pedal box? Spridgets 2
LuckyLuke 100-4 brake / clutch pedal seals not available Austin Healey 3
D No play in brake pedal - what a drag? Triumph 7
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
B gas, Brake, Clutch Pedal covers? Spridgets 8
saabmp3 weak brake pedal Spridgets 5
J Newbie - Soft Brake Pedal Spridgets 14
B XJ12L 1975 SOFT BRAKE PEDAL Jaguar 11
AUSMHLY brake pedal push rod adustment - YIKES ! Austin Healey 9
tr6web TR6 TR6 leaking at brake pedal Triumph 12
W Mystery of the re-occuring soft brake pedal Austin Healey 10
6 Brake Fluid Spridgets 4
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
